Bosch III'S Reprogramed/wrong tune advise
Old Sep 6, 2011 | 03:55 AM
Qiken's Avatar
Qiken
Default Bosch III'S Reprogramed/wrong tune advise
I recently had a piggyback chip done by a local on line Tuner,
(89 VETTE,AUTO,3.07)
Told him I had ZZ4 cam,1.5 roller tips, ported plenum/intake manifold, magnaflow cat etc and already had ARAP prom.
and Bosch III's set using AFPR @ 43.5lb
On having the piggyback chip read,seems like all he has added(aside from VATS/EGR delete is
as appears he uses the ARAP anyway as a base tune
1. Lot more spark advance up top(why?)
2. Fans now set at 199 / 193F?
3. Injectors Now 21.20 vs stock 22.36
4. Idle set at 700
Old Sep 6, 2011 | 08:46 AM
bjankuski's Avatar
bjankuski
Why are you questioning the tune? He is running it cooler, raised the idle for the cam, changed the injector constant (you didn't mention what you had for size) and added more timing from an unknow base. Does it run poorly?
Old Sep 6, 2011 | 08:52 PM
Qiken's Avatar
Qiken
22lb Bosch III's
It just seems to perform better without the piggy back chip
Old Sep 6, 2011 | 11:24 PM
JackDidley's Avatar
JackDidley
You need to datalog to see what it really needs.
Old Sep 7, 2011 | 01:22 PM
monkihead's Avatar
monkihead
+1
I request a datalog any time a mod has been made.
To Bosch III'S Reprogramed/wrong tune advise
