Electrical Problem
Old Apr 30, 2002 | 10:29 PM
wi_philly's Avatar
wi_philly
3rd Gear
Default Electrical Problem
I have been having the strangest problem that I and the mechanics cannot figure out.... My volts are good at 13.8-14.3 but if I het the brakes everything in the dash and the headlights flicker. The voltage does not seem to drop, if it does, I cannot get a reading... I have looked for a bad ground all the way back to the back lights and can find nothing...
Any ideas would be appreciated.
Old May 1, 2002 | 01:45 AM
jfb's Avatar
jfb
Default Re: Electrical Problem (wi_philly)
This sounds like your voltage regulator in the alternator is oscillating when you have the brake lights on. Unplug the connector from the alternator and the alternator will be off. If you apply the brakes and your dash lights flicker, then you can probably get into the Guiness book of world records for weird car electrical problems. :D Also, you can use an oscilloscope to look at the battery voltage waveform (alternator working) with the brakes on and you will see the sudden appearance of the oscillation. Most ignition analyzers allow you to look at the voltage waveform on the battery so your mechanic could observe the oscillation.
