pcmforless vats delete chip
Old Sep 7, 2011 | 01:57 PM
mintc's Avatar
mintc
Default pcmforless vats delete chip
well i installed my vats delete chip in my 92 today to see if that would cure my no start, and it didnt. But i noticed that with it installed it is still showing my vats is enabled in my obd 1.3, 01 still reads 1 maybe i got a bad chip, sending it back today
Old Sep 7, 2011 | 02:13 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Ok
Old Sep 7, 2011 | 03:29 PM
Flame Red's Avatar
Flame Red
92 may be different, but in my 90 ODB1 car the VATS in the ECM will just turn off the injectors so that the car will not run. It does not control crank. The CCM also has a VATS and will not permit crank.
The comprehensive solution is the VATS eliminator, which will fake out the resistor code and bypass the entire system (both CCM and ECM). I got the one from MidAmerica but there are many others that are cheaper.
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
no start or no crank?
Two different things. IIRC the chip just tells the componnents not to check the vats pellet. It doesn't really "disable" anything.
There are lots of folks that have had the crank - no start problem. The FSM is the BEST place to start.
Old Sep 7, 2011 | 05:03 PM
mintc's Avatar
mintc
cranks no start. the vats delete chip is supposed to turn off vats in the ecm, but it didnt, it still shows it is enabled still , the guy i talked to said to send it back for testing
Old Sep 7, 2011 | 05:14 PM
mistaben's Avatar
mistaben
... just read the resistor on your key and hotwire the vats?
Old Sep 7, 2011 | 05:43 PM
mintc's Avatar
mintc
its not the key part of vats im having problems with. i already installed the bypass for the key, now i am trying to disable the vats that controles the fuel enable signal. i have no injector pulse and have already checked the wiring, grounds, injectors, plugs, dizzy reference, and had the ecm remaned, the only thing left is the serial port communications from the ccm to the ecm, aka vats
Old Sep 7, 2011 | 09:18 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Have you followed all the "crank no start" troubleshooting steps in the FSM?
IIRC not seeing the Opti turn will also fail to trigger the injectors.
Good Luck
Old Sep 7, 2011 | 10:38 PM
rodj's Avatar
rodj
Originally Posted by mintc
i already installed the bypass for the key, the only thing left is the serial port communications from the ccm to the ecm, aka vats
Not VATS directly
If you have DTC 41 that means a loss of comms to the CCM which prevents the ECM from seeing the required signal.
Very common problem on early CCM cars
http://www.digitalcorvettes.com/foru...5&postcount=17
http://forums.corvetteforum.com/1554993058-post25.html
http://forums.corvetteforum.com/c4-s...cm-or-ccm.html
Old Sep 7, 2011 | 11:00 PM
mintc's Avatar
mintc
Originally Posted by rodj
Not VATS directly
my problem is i have no dtc's
To pcmforless vats delete chip
