I have a 94 that intermitenly at 70 mph has what feels like a miss. Put the cruise on an it goes away. Just does it every once in a while. Any suggestions?
Check to see if any coolant is dripping out of the water pump weep hole onto the opti. Kind of a pain, but run your fingers around the bottom of the water pump until you feel the little weep hole, then check to see if your finger got wet.
