1994 convertible hatch release
The hatch selanoid is basically a coil of wire like on an electric motor. When you hit the button, it charges the coil and moves a lever that allows the hatch to open. When these start to go bad, the resistance of the device goes down. If resistance goes down, amps go up. You were blowing your 10 amp fuse because the selinoid was going bad and drawing amps. It's probably blown now. Get to the selanoid and put a multimeter on the connector. Then, press the button and watch the multimeter. If you see voltage, than your selanoid is bad.
The P/N for it is C4-RHS-8496. Here is one at Corvette Salvage. A little pricey, but you can check fleabay too.
The hatch fuse calls for a 25 amp. Using a 10 amp which is less than half the rated value called for, I would expect the fuse to blow. The fuse powers the solenoid for the hatch release and the coil for the hatch relay. Most of the current goes to the hatch solenoid and a small portion (maybe less than 1/2 amp) goes to the hatch relays coil. If it is working with the 25 amp, then all is good and it's working properly.
