Compression test questions
Old Sep 10, 2011 | 09:37 AM
oldtee's Avatar
oldtee
Default Compression test questions
Do you do differential compression (known as leak down) tests on these engines?
Won't they tell you more than a steight compression test?
Background:
Just bought a 91 (L98) and very new to Corvettes. Former Porsche owner and aircraft mechanic. Don't know my way around the engine yet and don't own a code reader (yet). Maint manuals on order.
Old Sep 10, 2011 | 10:17 AM
1963SS's Avatar
1963SS
As you know a leakdown test can more easily pinpoint problems with an engine. It's easier to hear burnt exhaust or intake valves and the old blow by issue and of course cylinder balance. Do you have a problem or expect to find a problem by doing this. If it's running well why go looking for problems? Since it's your first Vette just go out and drive and enjoy it. Unlike a Lycoming or Continental engine, if your's quits you're not going to corkscrew into a cornfield in Iowa at 150 MPH.
Old Sep 10, 2011 | 10:31 AM
87 vette 81 big girl's Avatar
You & I are from the same school of Hotrod Insanity.
LOL
Corkscrew & crash & burn..........LOL
I have to drive down to Kentucky this fall & hang out.
You can smoke by me very fast forward in your Vette against my 87 vert.
No 410ci in yet.
Be a good time
Brian
Old Sep 10, 2011 | 10:42 AM
Background:
MOROSO makes the very best cylinder leakdown gauge for the average enthusiast.
Have a MAC leakdown tester too.
I hate the MAC.
Lies easily.
Old Sep 10, 2011 | 11:42 AM
oldtee's Avatar
oldtee
Thanks, driving is the plan as soon as I get plates on it. In my searches around here I didn't come across any mention of leak down. Things may be a little harder to reach and it is a good diagnositc tool.
What model code reader should I buy?
Corkscrew??? Aircraft don't quit flying until they run out of air over the wings, then... bump!
Ask a pilot what he does if his engine quits at NIGHT!!
Answer: You turn on your landing light, and if you don't like what you see, you turn it off!
Old Sep 10, 2011 | 11:55 AM
1963SS's Avatar
1963SS
Oh.......I was talking about it blowing up while practicing impending stalls as your plane quits while breaking to the right Quick...hard left rudder, hard left aileron and drop the nose. Been there....done that
Now that's funny, right there.
Old Sep 10, 2011 | 12:25 PM
1963SS's Avatar
1963SS
Cool, wait until MY engine's done then we'll have to have some fun.
Yep, a whole big bag of torque and RPM that would make a turbine cry.
Be a good time
What? Beer and bench racing.....ya' think
Old Sep 10, 2011 | 03:30 PM
samsonb's Avatar
samsonb
When you run a standard compression test. Are you doing it on a hot or cold engine? The FSM doesn't mention anything about the temp of the engine when doing this test.
Some say do it on a warm engine, others say do it on a cold engine. I have heard the numbers can get scewed when doing it on a warm engine as by the time you get to the last few cylinders, the engine has cooled down and lowered the compression results.
Others also say not to remove the spark plugs on a warm engine as it could gall the threads.
Old Sep 10, 2011 | 03:37 PM
cv67's Avatar
cv67
St. Jude Donor '05
You can get a code reader from Oreillys
One is 59 which reads them, one is 79 or 99 which reads, resets and does some other functions (obd and 2). Easier than screwing with a paper clip under the dash.
on the to buy list.
Old Sep 10, 2011 | 03:57 PM
1963SS's Avatar
1963SS
Obviously a hot (operating temp) engine would be ideal but primarily we're looking at cylinder balance. You couldn't be sure that the temps of the pistons and rings will be the same from when you start the test until you finish and results could be skewed. Also remember that even if it is hot, when you start injecting cold air into it they cool down quickly. That would be very quickly in the case of the compression ring with airflow all around it.
For these reasons I always do them cold. I've been removing spark plugs for a few years now and I've done them hot, warm and cold. I've never galled a thread in my life. Based on my experience I would think it's not too important. I'm sure there's a tech article that will disprove what I said but if it doesn't make a difference then.......poopy on it.
Well horse snot. I just re-read your question and you said a standard compression test. Same thing, cold is just fine. Make sure your throttle stays in the same position for each cylinder. Stick a tool of some sort in the TB opening and leave it there.
Old Sep 10, 2011 | 04:39 PM
JackDidley's Avatar
JackDidley
Background:
Dont really need a code reader. Jump the A + B terminals at the ALDL and count the flashes of the service engine light.
Old Sep 10, 2011 | 05:07 PM
samsonb's Avatar
samsonb
Yeah, cold would definitely be easier. Plus the engine would cool down alot by the time you get the plugs out and everything setup to do the compression test if you warmed it up first.
I've got an extra 75 battery. So, I'll do four cylinders on one battery. And then swap in the other battery for the other four cylinders since you're going to be cranking it over 4 times a cylinder.
Old Sep 10, 2011 | 05:12 PM
1963SS's Avatar
1963SS
One battery should be good if you're just cranking a short while. With the compression tester in place you'll see when to quit. It will stop increasing. If you pull the plugs (8) first it'll crank easier and give you a few more RPM's also. Good luck. If you don't mind, post the pressures. It's been awhile since I've seen something near stock and my memory needs boosted.
Old Sep 10, 2011 | 10:43 PM
Play 1st in the Corvettes.
Run them.
Smoke me when you shift at 7,500 RPM's.
Take me for a ***** out ride in your Race Vette.
Then I take you for a ***** out ride in my car.
Then beer & hamburgers & bench racing till we both drop.
Old Sep 11, 2011 | 07:27 AM
oldtee's Avatar
oldtee
Do you pull a fuel relay somewhere? I would think all that cranking would pump raw gas into the cylinders and that can't be a good thing, can it?
Old Sep 11, 2011 | 08:33 AM
1963SS's Avatar
1963SS
Oops, good point. I always do my testing on LT1's at WOT so it's not a problem but yes......if you're less that WOT, pull the fuel pump fuse or something. Thanks.
To Compression test questions
