lq9 in c4
Old Sep 10, 2011 | 09:55 AM
tuteNpuddle's Avatar
tuteNpuddle
Default lq9 in c4
deciding to buy a built lq9, its actually a turn key motor. I have a 96 auto, will it mate up to my tranny? i just need all the info i can get.
Old Sep 10, 2011 | 10:17 AM
87 vette 81 big girl's Avatar
The LQ9 - LS 366 cubic inch 6.0 L V8 will bolt up to your C4 4L60E transmission just fine.
Did you get the 4L65E auto trans that was bolted up to your LQ9 also ?
That transmission has Top Notch GM 5- pinion forward & rear reaction planetary gearsets & full torrington needle bearing thrust washers throughout.
Geartrain a direct & easy swap in place of C4 4L65E & 700 R4 parts.
Reuse your stock C4 input drum & turbine shaft & front pump assembly.
& reuse your output mainshaft, main trans case, valvebody, & special "C" beam tailshaft extension housing.
BR
