93 A/C programmer
Old Sep 12, 2011 | 03:08 PM
Rick Walker's Avatar
Rick Walker
3rd Gear
Default 93 A/C programmer
I need help. Where is the A/C programmer located on a 93. Is it behind the controls and if so how do you access it. It's not under the drives side insturment panel or if it is I can't find it.
Old Sep 12, 2011 | 05:07 PM
Hooked on Vettes's Avatar
Hooked on Vettes
It's mounted on the firewall. It's a black plastic case
about 4x6 inches mounted by a single bolt above
the gas pedal/driverside transmission tunnel
area high on the firewall.
You get to it by removing the driver side foot well
panel that contains the driver side courtesy
lamp.
It has one electrical connector plugged on the top of it and
a group of vacuum hoses plugged into the top right
corner of it.
The picture in the manual shows the outline of the
instrument panel dash cluster in a lower position
relative to the AC programmer than what it really is.
Old Sep 12, 2011 | 05:08 PM
RLG's Avatar
RLG
It's there you have to look back toward the steering wheel to see it. It had a gang of vac tubes and a long electrical connector.
Old Sep 14, 2011 | 12:44 AM
93VettePilot's Avatar
93VettePilot
You have to move the drivers seat all the way back and lay upside down in the driver side floorboard. Look straight up with a flashlight. You will see it. It has a bunch of colored vacuum hoses going to it. 7mm screw bolts it in and there is a nasty clip that holds the vacuum harness in place. When I reinstalled it I left the clip off because there was no way that vacuum harness would come off without someone pulling it.
Old Sep 14, 2011 | 01:47 PM
pcolt94's Avatar
pcolt94
Well.....now that you know where it is, why do you thing you have to go there. What kind of problem are you having? They dont fail very much, would like to know you symptoms before you tear into it.
Old May 13, 2017 | 12:16 PM
Corvette 1993's Avatar
Corvette 1993
Default Corvette1993
Do you know where each five vacuum lines go to, and what they are for? I want to put in a new harness, but would like to know what I'm getting into.
Old Nov 22, 2017 | 11:12 AM
Gary Bagley's Avatar
Gary Bagley
Default C68 HVAC Programmer
Finally got the C68 HVAC Programmer removed the back of the board looks like there is something burnt out can some one tell me what other years would fit the number is the side of mine is 16143361
Old Nov 23, 2017 | 02:10 PM
pcolt94's Avatar
pcolt94
I would like to see a picture of the board to see exactly what your talking about.
What are the problems and exact symptoms that you are having.
Old Nov 23, 2017 | 03:50 PM
Gary Bagley
there is a small part burnt out on the circuit board
i phoned Bryan Thompson at Batee today to get a price
to repair and ship back to me in the uk
Old Nov 24, 2017 | 10:20 AM
pcolt94's Avatar
pcolt94
What part?
That is the solder side with surface mounted resistors and capacitors. The other side is the component side. Or am I just not seeing it?
What were the original problems?
Old Nov 24, 2017 | 10:29 AM
Gary Bagley
Default HVac
What part?
The part that is burnt is in the middle of the picture if you enlarge
The photo you will see it
The parr is the a/c programmer
To 93 A/C programmer
