Hood clearance problem with super ram
Old May 1, 2002 | 02:50 PM
Corvette0096's Avatar
Corvette0096
Default Hood clearance problem with super ram
I have a Superram with a Edelbrock 52 mm and the T\b is rubbing underneath the hood there a way to fix this? I removed the screws and it is hitting on the Edelbrock plate now. Car has never been hit. 85 vette
Old May 1, 2002 | 03:01 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Default Re: Hood clearance problem with super ram (corvette0096)
You could put a couple shims under the hood hinges in the front where they are bolted to the front end.
Old May 1, 2002 | 06:10 PM
Corvette0096
Default Re: Hood clearance problem with super ram (AquaMetallic94LT1)
Then my front bumper will not be lined up..
Old May 1, 2002 | 08:44 PM
drive it's Avatar
drive it
Hmmm, something's not right; it should be the same hgt. if not a little less. Did the original tb and plenum/runners rub?
Old May 1, 2002 | 08:45 PM
snaketr's Avatar
snaketr
Default Re: Hood clearance problem with super ram (drive it)
The front bumper also adjusts. However if it did not rub before it should not be rubbing now.
Old May 1, 2002 | 08:53 PM
AquaMetallic94LT1
One shim on each side is not going to make that much difference.
Old May 1, 2002 | 09:26 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Just a thought...can they adjust the hood stop screws?The ones with the rubber caps on them?I replaced the rubber caps once and the hood sat better since the old ones were flattened down by being 15+ years old.
May be worth a shot.It could make the hood sit a MM or two higher which may help.
Btw I couldnt adjust the screws.They rusted in place but figured GM got it right so just the 4 rubber caps could use replacing and leave the screws alone.
Old May 1, 2002 | 10:45 PM
Corvette0096
Default Re: Hood clearance problem with super ram (Bill's86Coupe)
I will try that
To Hood clearance problem with super ram
