Speedo gear removal
Old May 1, 2002 | 05:57 PM
NHVett's Avatar
NHVett
Cruise-In I Veteran
Cruise-In II Veteran
Default Speedo gear removal - solved
I am swapping my tranny for a built-up unit. I need to put my old output shaft housing and the speedometer gear on the new tranny. How do you remove the plastic speedometer gear without ruining it?
Solved it with boiling dihydrogen oxide. Slipped right off. ;)
[Modified by NHVett, 6:06 PM 5/1/2002]
Old May 1, 2002 | 10:30 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Speedo gear removal - solved (NHVett)
For any that may not have that hydro-dioxide whatever stuff. There is a small metal clip that holds some of the gears to the output shaft. you need to use a small awl to pull up on the clip and then slide the gear off. At least I think it was lift up on the clip and slide off. Maybe it was push down on the clip and slide off. Anyway one of the two should get it.
