Bottom end strength?
Old May 1, 2002 | 06:10 PM
C4-Wolf's Avatar
C4-Wolf
Default Bottom end strength?
Allright, looks like the winter project is finally ending. I believe I will be ready to fire up the new build this Thursday, and just had a couple of questions about the bottom end strength.
I have LT4 rods and an LT4 crank in the motor right now. It looks like I will be turning about SAE 525hp and 475tq at the crank. At this altitude actual output will be considerably less - probably 20% less. I would assume an LT4 crank and rods are OK with this, but what about rpm's? Are they good for up to 6500? It looks like I will be hitting max power at 6300, but I will have to dyno obviously to be sure.
Old May 1, 2002 | 11:10 PM
bogus's Avatar
bogus
Default Re: Bottom end strength? (C4-Wolf)
yer ok.
the bottom ends are good for upwards of 8000rpm or so...
Old May 1, 2002 | 11:37 PM
tpi 421 vette's Avatar
tpi 421 vette
Default Re: Bottom end strength? (bogus)
I think 8000 rpm on a stock bottom end is a little high.The powdermetal rods are rated to 450 hp.
I think you would be safe to 6500rpm
Old May 2, 2002 | 01:50 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Your bottom end will handle the hp. Bottom end strength limits rpm potential. The stock LT4 had a redine of 6400. I would not go over that much without going to better rods.
Old May 2, 2002 | 08:27 PM
C4-Wolf's Avatar
C4-Wolf
Default Re: Bottom end strength? (AquaMetallic94LT1)
Good to know, thanks for the replies.
To Bottom end strength?
