92 vette h64 code
Old Sep 16, 2011 | 06:30 PM
mintc's Avatar
mintc
Default 92 vette h64 code
i keep getting this code in sec 9 even after i unhook the batter for periods of time section 1 gives me the c12 4 has --- and 9 has the h64, i looked it up online and it say something like right bank lean but y would that b in section 9
Old Sep 16, 2011 | 06:35 PM
c4speed's Avatar
c4speed
From: Atco Raceway in between Pa & Nj 13.073 @ 106 MPH
History 64 right front O2 sensor, check the wiring for the sensor first for cuts ,cracking then trouble shoot.
Old Sep 16, 2011 | 06:38 PM
RockHeadss's Avatar
RockHeadss
St. Jude Donor '10
http://tech.corvettecentral.com/2011...trouble-codes/
hope this helps you out
Mark
Old Sep 16, 2011 | 07:31 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I had that code pr problem with my 92. I bought a new O2 sensor and that was not the problem.
People told me it could had been the mix, too lean, too rich etc. It was a PITA.
I hope all goes away if you install a new one.
Old Sep 17, 2011 | 04:34 AM
toptechx6's Avatar
toptechx6
Is the ABS light on? Module 9 is the anti-lock brake controller. If the light is on you will need to follow the diagnostic sequence in the Factory Service Manual for your year vehicle, but since it is a history code the problem may no longer be present.
The code should clear itself after a number of restarts if the problem is resolved, or you can use a Tech1 scan tool to clear it immediately..
To 92 vette h64 code
