please help
Old Sep 17, 2011 | 09:07 PM
c4freak209's Avatar
c4freak209
3rd Gear
Default please help
i have a 1985 corvette that im puttin back together and everywhere i go they say that the exhaust manifold bolts are discontinued and they cant even tell me what size and how big they need too be. can somebody please tell me what size they are or even where i can buy the set.
thanks, rick aka. c4freak
Old Sep 17, 2011 | 09:30 PM
87 vette 81 big girl's Avatar
Exhaust manifold bolt thread size is 3/8" X 16tpi.
Or same as 3/8" standard coarse thread , 16 threads per inch.
Length ?
Recheck with a tape measure what you need.
Check the exhaust manifold mounting flange(s) thickness with a tape measure.
And add at least 1/4" inch to allow enough thread engagement into your cylinder heads.
Old Sep 17, 2011 | 09:40 PM
Joe C's Avatar
Joe C
from what i'm seeing in the parts manual, the bolts are 3/8-16X2.00. there are also some studs - called out as 3/8-16X4.093 and used on the LH #3 hole. another stud, dimensions not called out, but used on #1-4 RH, and #3 LH holes. it's a little confusing - - i would think the studs are used with brackets and braces for the alternator, and most likely the AC compressor. -??? - man, i hope this helps...
Old Sep 17, 2011 | 10:20 PM
c4freak209's Avatar
c4freak209
3rd Gear
thank you to those who have answered ill go do my searching and homework now and see what happens.
thank you again.
Old Sep 17, 2011 | 11:17 PM
joeld's Avatar
joeld
I just bought some of the double studs for my 89 from the dealer. I'll check the numbers if I can find the package Sunday. Meanwhile, this will give you some info that's usually correct.
Joel
http://www.compnine.com/index.php?u=...00&grouptype=B
Old Sep 18, 2011 | 05:01 AM
Joe C's Avatar
Joe C
Joel
cool site. bookmarked that one for my database...
Old Sep 18, 2011 | 11:37 AM
joeld's Avatar
joeld
OK, the part # for the "double" stud I bought is 12550726 which is the same as a 85. I would "assume" the regular exhaust bolts are the same and available thru GM parts.
Joel
Old Sep 18, 2011 | 04:10 PM
c4freak209's Avatar
c4freak209
3rd Gear
Default thank you
thank you for those diagrams they are a big help deff. bookmarked and even printed for file. thank you again
Old Sep 18, 2011 | 04:13 PM
navy_vette's Avatar
navy_vette
Joel
I really like this........ bookmarked, printed, saved, copied and remembered for future reference.
To please help
