D.U.I. or MSD?
Old Sep 21, 2011 | 09:33 PM
Casshern's Avatar
Casshern
Default D.U.I. or MSD?
Which would you pick? Which do you prefer? What can you say about either? Looking for your opinions so I can make a solid choice!
Tried looking for a definitive answer, but looking for some fresh and current information.
This is the MSD kit I'm currently looking at:
http://www.jegs.com/i/MSD+Ignition/121/85551K/10002/-1
This is the D.U.I. series I am interested in:
http://www.performancedistributors.com/gmracedui.htm
Any info you have, would be greatly appreciated! Thanks!
Old Sep 21, 2011 | 09:39 PM
cumbercr's Avatar
cumbercr
I went with DUI. They are a family run company and stand behind their products.
Old Sep 21, 2011 | 10:18 PM
oldalaskaman's Avatar
oldalaskaman
they're both good , I've run both, I like DUI cause of the support, I like MSD cause of all the extra gizmo's that you dont really need but look really cool, they both work well. You call MSD , you leave a message and they call back, you call DUI and you talk to them right then.
Old Sep 21, 2011 | 11:26 PM
87 vette 81 big girl's Avatar
DUI.
Davis Unified Ignition.
I have a spare DUI HEI upgrade kit with their ignition module, Coil, Cap, & rotor in the garage I keep at all times.
In case a local racer needs it.
Much more reliable than MSD's when racing.
No spark box to fail suddenly.
Lose the race then.
Has happened several times that way for people I have known using MSD's.
Knew 1 frustrated racer that took his MSD box off & smashed it with a sledgehammer.
Old Sep 21, 2011 | 11:31 PM
Tunedport90's Avatar
Tunedport90
Don't think either one will be computer controlled if that's the way your headed.
Old Sep 21, 2011 | 11:35 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
D.U.I. for me too.
Old Sep 21, 2011 | 11:40 PM
383vett's Avatar
383vett
MSD here.
Old Sep 21, 2011 | 11:44 PM
DUI offers the TPI - L98 ignition modules also.
7- pin ignition modules.
& Vortech style ignition modules that mount on a separate heat sink.
They have a website.
Check it out for yourself.
Old Sep 21, 2011 | 11:48 PM
Crepitus's Avatar
Crepitus
I have used both, and they each did the job just fine.
DUI, support is exellant, no box to wire or mount, cheaper, But no built in rev limit, one is available as a add on.
MSD, has an adjustable rev limiter, very expandable with retard boxes ect, I have had a box crap out on me. Trouble shooting guide is on their web site.
Old Sep 21, 2011 | 11:59 PM
rodj's Avatar
rodj
Don't think either one will be computer controlled .
http://www.summitracing.com/parts/DUI-12600BK/
http://www.summitracing.com/parts/MSD-8366/
Old Sep 22, 2011 | 12:04 AM
856SPEED's Avatar
856SPEED
the name D.U.I. scares me!!
don't know anything about that set up but I had an expensive MSD 6AL box take a sh_ _ on me and it wasn't that old.......been w/o it for a while and I can't tell it is gone.......
Old Sep 22, 2011 | 12:18 AM
D.U.I.
Davis Unified Ignition Systems.
Used to be Memphis Distributors.
Same company & owner,
changed the company name in the late 1990's.
They have been around since 1986.
I have a copy of their original 1986 product catalog here at home.
I have Lots of racing literature & catalogs from 1960's to present.
I save it all.
Brian
Old Sep 22, 2011 | 12:20 AM
DUI custom builds distributors for all makes & models.
Domestic V8's & V6's.
Call them.
Old Sep 22, 2011 | 12:22 AM
856SPEED's Avatar
856SPEED
Originally Posted by 87 vette 81 big girl
D.U.I.
I save it all.
Brian
Thanks; good information; maybe I'll try that one next time!
Old Sep 22, 2011 | 03:21 AM
navy_vette's Avatar
navy_vette
When I do get a new distro, I'm going with the DUI. Drop-in install and no extras to mount or wires to run.
You'll have to upload those documents Brian. I would like to see them!
Old Sep 22, 2011 | 04:28 AM
OK.
I am computer handi capped mechanic if no one has ever told You or not.
Wife does have a scanner here.
Only she knows how to do that stuff.
Have lots of cool vintage magazine write ups from back in the day when these C4's were new.
Think everyone would enjoy the reading & pics.
Find lots of cool things on ebay for $.50 cents to $2.
Old Sep 22, 2011 | 03:32 PM
oldalaskaman
OK.
Dude, seriously, 'puters are just tools, with your mechanical skillset it might take you a whole 1/2 hr. to learn evertyhing you need or will ever use on one of these things
Old Sep 22, 2011 | 04:16 PM
Rohn's Avatar
Rohn
I am going diff route for my N20 use.
I am keeping original GM dist. replacing the module and coil with:
MSD-8401 HEI cap
SUM-G5215 external coil
Summit ignition box($145)
MSD replaces the stock cap that hides the internal coil and gives a place to plug the external coil into.
And a coil wire from autozone. Now I see DUI does not offer a rpm limiter. That is good as my ECU can handle that.
To D.U.I. or MSD?
