alternator? - low battery voltage issue...
Old Sep 22, 2011 | 02:28 AM
mistaben's Avatar
mistaben
Default alternator? - low battery voltage issue...
was reassembling the block from putting in a new water pump and was trying to get battery voltage wire off... and started twisting the nut and the stud twisted with it.... twisted back in place and just left alternator alone during water pump install.
reassembled car, took it through emissions drove home.
took it out tonight and low battery voltage, stumbling now dead.
who makes a rebuildable alternator?
oreily's or autozone or checker? - are they all the same?
Old Sep 22, 2011 | 04:35 AM
87 vette 81 big girl's Avatar
Pretty much all the same quality.
O'Reily's being the top pick from your list.
I would have your original alternator on your Corvette right now rebuilt for around $30 from local auto electrical repair shop.
You should have 1 nearby somewhere.
BR
Old Sep 22, 2011 | 09:08 AM
Muffin's Avatar
Muffin
BR
If your alternator was functioning correctly there is a good chance you can simply have the stud replaced. That would cost about $10. at our local auto electric shop.
Old Sep 22, 2011 | 11:09 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Find a local Alternator shop. Its worth the price.
You'll be replacing parts continously when buying from AZ or the others.
Old Sep 22, 2011 | 01:10 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Of course while at the shop they should test other components. They will have to crack open the case to replace the post anyway..
Old Sep 23, 2011 | 03:22 AM
mistaben's Avatar
mistaben
*deep painful groans...*
i forgot to check the forum boards... I just got done today driving out to the west side of Phoenix valley to get the only lifetime warranty alternator offered from NAPA for 120$...
and yea the old one failed the alternator test at autozone... put the new one in and it is back to running like a charm. I will spend time tomorrow A) datalogging B) driving around randomly looking for an auto electrical repair shop. - that is too expensive to do twice.
To alternator? - low battery voltage issue...
