Engine Problem
I am always suspicious when guys say their c4 is "normally" cool, but has running issues. I also notice that when CTS is mentioned as a potential cause, many people ignore it. I guess the assumption is that O2 sensors are in control. If you follow the forum you will see many issues with CTS as a root cause, so it pays to question everything.
joe
joe
I have only been a C-4 owner for a month now, and I have recieved more help and expertise advice here than from anywhere else. My biggest problem is I know enought to get me in deep doo doo most of the time. So to all thats helped thanks again and maybe someday/somehow I can repay you all. Will update with results from new CTS.
others noticed the temp, too. these threads are crap shoots, you know? no one knows as much about the problem as the OP, so it's a guessing game. I might have been lucky.
when you remove the yel and blk 2 wire plug, I think you can check the terminals for 5v. the harness is part of the circuit. most likely the sensor.
saludos, joe
*** the fsm does not mention that the sensors fail without setting codes. I got that from a thread a week ago, from member SunCr. seems to be common.
saludos, joe
? What sensor is on the driver side head between the intake and manifold? It looks like the connector is cracked! Did't have time to investigate it yet.
the knock sensor is in the BLOCK, as you prob knew, but may be in the front location. my 91 has a sensor "gage overheat" but I am not familiar with it.
, not sure how ecm uses the actual gage, or if it does. got confused in previous post thinking CTS sent a signal to gage like oil temp sensor but it does not.
need to review my fsm to get my thoughts collected!
joe
have had a problem for some time with this page, often deleting part of the page, esp when inserting
or other.*** now that it is too late, I realize that the sensor for the digital temp gage AND the red overheat light are controlled by that sensor I mentioned -probably the one you are seeing. The one you unplug accidentally when changing 6-8 plugs! I mentioned in a thread some time ago that the temp gage and CTS were not the same, but had forgotten why.
good thing you are not celebrating too heavily! the low temps are a clue, but not the solution, looks like.
Are you sure you have all the spark plug wires in the right holes in the distributor cap?
I will try to find the right parts (CTS) and install next week also.
Leaving town for the wknd for a fishing tourney. Maybe I can find some luck fishing!
Thanks again to all for the help. I will not give up, relentless!
Bad plug wire
REDTREX - I have replaced the 02 sensor and the plug wires. O2 sensor went in with the new exhaust replaced a month or so ago. Could have a bad plug wire. I have never seen a new one go bad, but possible.
When the code came in the car car "stumbled" for a second on take off. Almost like it quit for a moment and then picked back up. Maybe this info will help in diagnosis?
I would like to get this thing running correctly before a long winter storage!!!
