Engine Problem
Old Sep 22, 2011 | 09:05 AM
basshooked's Avatar
basshooked
Default Engine Problem
Well, I'm at a loss now! I will admit defeat and look to this forum for some help. Hope someone can at least diagnosis the problem. I have looked at a few local shops for help and most are not willing to troubleshoot for whatever reason. Dont want to send it back to Chevy!
1988 stock motor L-98, is missing, constant and get worse as motor gets warm. I have administered the following meds and checked the following pulse rates: New plugs and wires, checked the FP-good at 40#and held for @20min, checked all the injectors, and inj harness' all good, checked timing, good set at 6*BTDC
I had to also replace the exhaust from the minifolds including new converter due to pluggage. Sounds much better except for the constant miss. What am I missing? any suggestions will be very thankful.
Old Sep 22, 2011 | 09:16 AM
Muffin's Avatar
Muffin
"checked the injectors" How did you do that? Cold,Hot? Both? NOID light? Codes? Can you isolate the miss to a cylinder(s) or is it random? Isolate to a bank? Obviously my knee jerk reaction is a problem in the fuel system.
Old Sep 22, 2011 | 09:37 AM
JackDidley's Avatar
JackDidley
Did you look inside the distributor cap ? Chek compression ? Remove valve covers and watch valve action ?
joe paco's Avatar
joe paco
have you noticed the engine coolant temp abnormal? or a rich exhaust, or tail pipes black? unplugged the MAF to look for a reaction? when unplugged, the ecm uses other values -maybe from the TPS- to determine fuel delivery signals. but it uses other values from various sensors, including the CTS.
can also unplug TPS -not at the same time as other sensors- but not sure about the CTS. what you want is a reaction while the sensor is out of the circuit.
as muffin said, should show a code if it is sensor related. if you have fsm, there are many pages, "symptoms" that guide you.
*** may not be high probablilty, but you can remove vac line to FP reg to check for fuel in the line -in case you see evidence of rich exhaust, from plugs, whatever. the deal is that it can be ignition, fuel, even things you have changed, spark lks, etc..
Old Sep 22, 2011 | 09:42 AM
pmihaltian's Avatar
pmihaltian
Slingshot
As already mentioned, you need to pull your codes and see what the onboard diagnostic system tells you.
Old Sep 22, 2011 | 10:02 AM
basshooked's Avatar
basshooked
I am limited on the code reader. Have the dime store model, spitting out code 12, the only code its ever spit out! I have not pulled valve covers or checked compression yet, hoping to not go there YET!
I also do not have the service manual for this car.
Some History:
Previous owner had replaced FI, Mufflers, brakes.
Car was purchased last month and was running good. After a few days of ownership, the skip developed. So I started with the plugs/wires, fuel filter, air filter, figuring it just needed a little tune up. nothing helped.
Old Sep 22, 2011 | 10:09 AM
basshooked's Avatar
basshooked
Whan I checked the FP, it comes up to @40# and it held there for @20min before starting to leak off. After an hr it ws down to #10 or so. Also took if for a spin with FP gauge on winshield so I could monitor, and FP stayed @35-36# at WOT. I would drop off to @22-24# when letting off the throttle.
I also checked the injectors cold first then somewhat hot after the FP check. The engine is not running hot, gauge showing @155-165*.
Tail pipes are clean, no smoke coming out exhaust. the old plugs did look a little white on tips to me. So I thought it might be running a little lean!
What type of code reader should I get and where to get it? The one I have is a Actron from Adv Auto.
Thanks to all for the help.
Old Sep 22, 2011 | 10:38 AM
JackDidley's Avatar
JackDidley
Odds are, you have no codes. Code 12 means the ECM is working. Another code reader will just tell you the same thing. If you have a laptop a scan program will get you good information. A dead miss has to be ignition or compression related since you have ruled out injectors. Maybe pull one plug wire at a time and isolate the miss to one cylinder ???
Old Sep 22, 2011 | 10:41 AM
joe paco's Avatar
joe paco
curious that the pressure drops so quickly when letting off throttle. the manifold pressure is higher, but never heard that mentioned before. not connected with the missing, maybe. also, engine is not rich, apparently, but the temps seem pretty low for a "warm" engine, barely in closed loop, according to fsm. as engine gets warmed up, o2 sensors control the fuel ratio, but if no codes are set...
you can verify that codes are being set by creating one. unplug TPS, start, then check for a code 21, I think. checking the sensors mentioned is free, nothing lost but time.
Old Sep 22, 2011 | 01:18 PM
RedTRex's Avatar
RedTRex
you haven't mentioned it but have you replaced rotor/cap yet?
Also - I would dump a can of Seafoam in.
and last thought is, has it done it on more than 1 tank of gas? from different stations?
Old Sep 22, 2011 | 01:32 PM
basshooked's Avatar
basshooked
No, I havent checked the cap and rotor. Dont even know why I havent checked it yet. I will check it later today. I have burned 2-3 tanks of gas through it all from the same Hess station. I use it exclusively when I can and have had no problems in other toys/vehicals. Thanks again for everyone's help. I will post later today what I find with the cap and rotor. Hope thats it! Everyone cross fingers, I'll hold my breath!
Old Sep 22, 2011 | 01:40 PM
383vett's Avatar
383vett
Do a leakdown test to make sure you don't have a mechanical problem before assuming you have a fuel or spark issue.
Old Sep 22, 2011 | 03:48 PM
SunCr's Avatar
SunCr
Really aren't any codes for a miss on an '88.
You need to determine if it's random or isolated to a single cylinder. Get yourself some 1/4 inch vacuum hose and cut it into 2 inch pieces. Remove each plug wire at the Distributor and insert one piece of your cut hose over the plug tower and insert the other end of the plug wire into the hose. Start it up and kill each cylinder by touching it with a grounded test light while observing a tach. The cylinder that doesn't drop - or drop as much as all the rest - is causing the problem.
Old Sep 22, 2011 | 05:25 PM
basshooked's Avatar
basshooked
Pulled cap and rotor. Looks like new, no arc crustation on rotor tip and cap "looks good". Might try a new one just to see.
Never seen this procedure done with the vac hose before. What kind of test light do I need? I have the reg 12v idiot test light. Will that work? Am I putting the rubber tubing over all or doing one at a time? I would like to try it but not completely sure how. Is there a video on You-tube or something I could watch it being done?
I believe the miss is random. but not 100% sure. all the old plugs looked pretty much the same when changing. I will perform a compression test later as work calls for my presence for the next 8 days.Thanks for the help and I will keep all that have helped up to speed.
Old Sep 22, 2011 | 05:41 PM
Muffin's Avatar
Muffin
The vacuum hose thinge will/does work but a mechanics stethoscope will work much better and not cost a lot of money.
Old Sep 22, 2011 | 07:21 PM
SunCr's Avatar
SunCr
Use a any 12 volt test light connected to ground - and that sounds like what you have.
Old Sep 23, 2011 | 07:24 PM
basshooked's Avatar
basshooked
Talked to a guy today that has a scanner. He said it would pull any codes and scan several parameters on the engine. He is actually a tranny mech, but he seem to know alot about this motor and the LT-1. Supposed to stop by tomorrow night after work and let him scan it to see if we can find out anything. If that does not work, guess I will try the vac hose and the test light.. Thanks again guys for all the help! Maybe some day I can repay you all in some way. Who likes to fish?
To Engine Problem
Old Sep 23, 2011 | 08:16 PM
stoydido's Avatar
stoydido
is the engine fully warmed up, still running 155* F? seems low to me, for a normal c4. if the CTS is reading low in error, it can affect the a/f ratio. even in closed loop, so fsm says. would make it richer, in this case, I think.
Old Sep 24, 2011 | 08:52 AM
basshooked's Avatar
basshooked
What I'm reading is the coolant temp on the digital dash gauge. It appears to be working correctly. It looks like the thermostat is opening at @160* and temp drops back down a bit and stays fairly stable between the 155 to 165 temp. I have never seen this temp above the 165 mark and lower than the 150 mark after engine warms up. Since I.ve owned the car, its never overheated and all indications that I see, the cooling system is working OK. ie: thermostat, cooling fan etc. I dont have the service manual yet, so not sure what temp should be!
What should the normal operating temp be at? Is this the wrong thermostat? How can I check the temp to verify its accuate with gauge on dash board? Hopefully tonight when we get the scanner hooked up it will tell me something that I am overlooking. Thanks!
Old Sep 24, 2011 | 09:14 AM
joe paco's Avatar
joe paco
the 91 calls for 195*. not sure where you are, but in Ky it was hot here for weeks. engine would climb above about 220* in slow traffic. if you have ever heard the fans cycle on, it was above "about" 230.
the concern is that if the temp is 230, example, and the temp gage is 155, the ecm would adjust fuel for the 155. Or, cts is not normal in its signals. its supposed to be in "Closed" loop at 104*, so says my fsm, so it may not matter. using signals from 02 sensors.
the high temp stat is for emissions control, but that is a huge part of the whole system.
may not be related to your issue, just looking for clues. you might consider a higher stat for winter.
