383 Stroker Opinion
Old Sep 23, 2011 | 09:56 AM
Tyloewen's Avatar
Tyloewen
Default 383 Stroker Opinion
I am debating if I should improve my HP and torque with a 383 stroker, the only thing is I have an automatic car. What are your thoughts on how I should go about doing this. Can I still do a 383 with an automatic? Its a 1985 with a L98 btw.
Old Sep 23, 2011 | 10:01 AM
cv67's Avatar
cv67
St. Jude Donor '05
Bigger is better
People having been building strokers for decades, no problem on your car too.
Old Sep 23, 2011 | 10:08 AM
1963SS's Avatar
1963SS
I agree that there's no problem. Bigger is better in most cases. I personally like the torque of a 383 but you would have to be a fuzz on the careful side when launching it. The Dana 36 rear may not be too happy but if you are not loading it up very much then you should be OK. Also your transmission probably won't last as long as you'd like in the stock configuration. Several hard shifts might just do it in.
Other than that....go for it. The 383 will leave you with a Joker like perma-grin on your face.
Old Sep 23, 2011 | 11:05 AM
Tyloewen's Avatar
Tyloewen
Just what I like to hear. Thanks for all the opinions!
Old Sep 23, 2011 | 11:14 AM
Dr.Huxtable's Avatar
Dr.Huxtable
Stroke it! You'll never look back. You can even stroke the block you have. Stroker cranks are not that expensive these days and brand really doesn't make that big a difference. After market will be less work and money as you won't have to turn the main journals down. Even stock rods can be used for 450 - 500 hp if your not turning 6k + Rpm for sustained periods of time. Get some good pistons though
Old Sep 23, 2011 | 11:48 AM
96 lt-4's Avatar
96 lt-4
383 is a great way to get a lot of torque.Bear in mind you will need to modify the intake,heads,and exhaust to take full advantage of the 383's potential.
Old Sep 23, 2011 | 01:00 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
If you do some reading, you'll find a consistent pattern of people needing/wanting to do some work to their tranmission and Dana36 after a signficant performance build. If you change the powerband (where it makes power), you'll want a torque converter. Depending on the gear ratio, how a 383 is setup, and how you drive it, people also end up converting to a Dana44 rear end.
There is a huge range of results for a 383 conversion. By just stroking it, you'll get 30hp but pick up torque all the way from idle to redline. And, it will be noticable. Depending on how you install the cam, you can get more low-end responsiveness. (On my 89, the stock config is to retard OEM cam timing IIRC.)
Of course, you can/should consider what to do in a car with a new bottom end. Will you get porting? Will you get new heads? Will you change the intake? Are you OK with the extra expense of bigger injecters and tuning? How about headers?
Your question is loaded at best. Any specific answer here is only as good as their PERSONAL interpretation of how you might build it and run it.
Old Sep 23, 2011 | 04:27 PM
stevie1dr's Avatar
stevie1dr
Go for it! you'll love it. Don't be so concerned about the Dana 36 handling it. If you really boost the HP, you'll want to change the converter and at that time, beef up the tranny. I run mine every weekend with a 3.73 rear gear and run in the low 12's without straining.
Steve
Old Sep 23, 2011 | 04:53 PM
Muffin's Avatar
Muffin
Bigger is better
I will be swapping out mine next month.
To 383 Stroker Opinion
