1991 RPM Gauge Problem
Old Sep 23, 2011 | 12:43 PM
SMosley's Avatar
SMosley
Cruising
Default 1991 RPM Gauge Problem
My 91, L98, six speed has a RPM gauge problem. When I turn the key to ON the RPM needle slowly moves upward, when I engage the starter the needle pegs at 6000, when the engine starts the needle drops to zero and does not move anymore. I bought a used cluster which the owner says worked fine but when I installed that I had similar problem. Help.
Old Sep 23, 2011 | 01:49 PM
bill mcdonald's Avatar
bill mcdonald
Did this start happening out of nowhere?
Did the tach act whackey prior to this issue?
I am wondering if you have a tach wire at the dist problem, or if your tach filter has failed.
When the tach filter fails, the tach will start jumping around and be totally inacurate. If the tach wire is not plugged into the dist, it should be plain dead.
Your issue as you describe it is a new one on me. Maybe someone with similar issues will be along.
Old Sep 23, 2011 | 01:57 PM
SMosley's Avatar
SMosley
Cruising
Originally the needle just kinda fluctuated up and down about 2000-3000 rpm, then awhile after that it just started pegging then dropping to zero when it started.
Old Sep 23, 2011 | 02:29 PM
bill mcdonald
Yeah that sounds to me like the tach filter.
It is mounted on the back of the driver side cylinder head. I believe it will have a white wire running into it from the distibuter. It looks like a cylinder, battery, capacitor etc...
The issue is, I dont know where you can get one.
What you can try to do is bypass it. One single wire. Tap in before, and after and see if it works.
I had it fail on me. I bypassed it, as well as used an MSD 6AL. no issues for me on my 90.
Old Sep 23, 2011 | 02:55 PM
SMosley's Avatar
SMosley
Cruising
Thanks Bill, I'll do that.
Old Sep 23, 2011 | 03:02 PM
SMosley's Avatar
SMosley
Cruising
Bill what is MSD 6AL?
Old Sep 23, 2011 | 03:52 PM
bill mcdonald
MSD 6al is a Capacitive Discharge system.
Suppose to put a little more juice into the spark plugs. This made me have to run my tach out from the MSD box. to the dash.
Nothing you need to worry about.
Old Sep 23, 2011 | 04:28 PM
SMosley's Avatar
SMosley
Cruising
OK, thanks for explanation.
To 1991 RPM Gauge Problem
