Which one is right?
Old Sep 25, 2011 | 08:29 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Default Which one is right?
I had a bit of a problem with the car dying when I put it in gear so I did the min. air idle procedure and all is fine now. When I put the scanner on it afterward I noticed the TPS reading was .47 but I had just set it with my digital voltmeter at .54. Should I set it by the scanner?
Old Sep 25, 2011 | 08:42 PM
oldalaskaman's Avatar
oldalaskaman
I would trust the multimeter, there could be other things affecting the running scan reading?
Old Sep 25, 2011 | 08:53 PM
HlhnEast's Avatar
HlhnEast
I would believe the reading at the source i.e. the multimeter at the TPS.
Old Sep 25, 2011 | 08:54 PM
Metal Brain's Avatar
Metal Brain
Cruising
"I did the min. air idle procedure and all is fine now" Means don't mess with it, just enjoy a job well done!!
Old Sep 25, 2011 | 09:30 PM
Midnight 85
Thanks guys.
To Which one is right?
