Antenna bypass help
Old May 2, 2002 | 05:27 PM
GS 163's Avatar
GS 163
Default Antenna bypass help
Ive had this harness lying around for awhile. Finally tried to install it today. The directions say to splice into the dark green wire coming from the amplifier relay. I did, no luck. Tried the green and black wire, no luck. What wire do I want???? It shouldnt be this hard. :rolleyes: Am I doing something wrong? Any help is appreciated.:)
Old May 2, 2002 | 05:46 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Antenna bypass help (JPLT1)
On my '88 it's the "pink" wire (always cut the pink wire:D).
Without a GM Shop Manual for your year the best bet is to locate the antenna relay to the left rear of the hatch and identify the wire color to be sure.
Old May 2, 2002 | 08:00 PM
GS 163's Avatar
GS 163
Default Re: Antenna bypass help (65Z01)
Yeah, the directions say 88 would be pink. I went and looked again at it. I dont know, I only see 2 green wires. Neither of them are it. :confused:
Old May 2, 2002 | 10:03 PM
Ramrod92's Avatar
Ramrod92
You'll need to find the pink wire at the radio control head. It should be in postion E on the C1 connector. :cheers:
To Antenna bypass help
