lt4 383
You can get a valve and port job to beef up the 383. Elliot Portworks has done few heads for CF members including myself. Visit his website, look, read and give him a call. A reliable local machine shop can also do that type of work.
EP also ported my intake.
As you thought, it is LT1 heads on the other engine because the LT4 has 2.00" valves in stock form and taller runners. The LT4 can potentially make more power and be more durable because of the radii cut on the crank. Make sure the engine you buy has factory 4 bolt mains also.
Don't trade yours in on the new engine because LT4 parts are bringing a premium.
Here is the thing.
When you build your LT4 - you know what your starting with. You also can buy the best internal componets you want/can afford to put in the engine.
Personally I've always tried to tailor my work to the customer and educate them on quality v/s $$$ spent. Last 5-10yrs I have also spend a bunch more time that I think I should have to managing expectations.... Don't come to me telling me about the build you saw on www.xxxx.com about the 530RWHP 9second F body using a stock LTX bottom end...... I know this sounds like an extreme example but some people really don't know BS when they step in it (or click on it).
I have a very simple method when I make recomendations on engine builds. Lets break this down and take it one thing at a time.
1. Cost.
How much do you honestly have to spend on the engine?
2. Performance.
What do you expect from the engine/car? HP or ET, driveability, mileage, ect.
3. Peripherals.
How much do you have budgeted for headers, clutch, gears?
4. Legality.
Emissions legal build?
Once you answered those you can have someone who knows what they are talking about start to price stuff out and see how good of a deal your "complete engine" is v/s something else.
Will
One of our sponsors has a balanced 383 rotating assembly for a little less that $1000. That would include a crank, pistons, rods, bearings and rings. You can get your LT4 bored .030 over for around $150.00 and clearanced for another $100-$150. Lifters will be around $130 and a cam around $250 or so. You could have a good street 383 LT4 for about $2000-$2200 if you choose parts wisely. A local machine shop would probably charge around 300 or so to assemble the bottom end and do the cam and bearing install if you'd rather not do it yourself.
A local shop around here just assembled an engine for a friend of mine and the machine work was:
Rebore Cyl with torque plate hone $150.00
Assemble piston and rods $40.00
Install cam bearings $35.00
Hot tank and clean all passages $50.00
Polish the crank $35.00
Engine assembly was $200.00
It's not as expensive as most people think and you'll know exactly what is in your engine.
A fresh valve job and springs on your heads will be sufficient.I have seen "ported" LT4 heads by a known guy lose performance.The runners are large and don't need to be ported to gain hp at the expensive of low end and midrange unless you are building a high rpm drag motor.A lot of people may disagree on this but it is my experience.I will be glad to share my experience and who it was via pm with the op.
Some bowl work and a killer valve job yes but I would'nt touch the runners.
The "EAGLE" cast 3.75" stroke crank and I-beam rods, are balanced, allowing the use of factory flywheel and front pulley! SpeedPro (10.4to1) compression, dished pistons (#H859CP) are fitted with SpeedPro moly rings. The camshaft providing 385hp and 410ft.lbs.torque, spec's are (220/224`@.050" with .505" lift on 112`LSA), with the factory steel 1.5 ratio rockers. Other cam grinds are available, call for details. A new Cloyes H.D. timing set and roller lifters are installed, with valvetrain preset, for quiet operation. A complete gasket set and NEW oil pump with screen are included, allowing easy completion of engine. Aluminum 1.6 ratio roller rockers available, for $200.00 extra.
This engine is hand fitted and assembled, by an ASE certified Master Machinist (me), with 26 years experience. Quality parts and workmanship, carry a 90 day parts guarantee, after start-up. This engine is built to order, taking appox. 3 weeks after recieving payment.
No core/exchange is required, saving you hundreds$$
Aluminum head or Iron head LT1, cost the same, only $2399.00 + freight.
granted there may be some delay, and it may be slightly more expensive than some prefabbed crate type engine, but in the short and long run I just don't see a down side to rebuilding your LT4 block.
any other opinions out there ???
1. Cost.
2. Performance.
3. Peripherals.
4. Legality.
Will
It cost money to go fast. Plain and simple...
