86 power steering pump problems
Old 09-26-2011, 11:04 PM
1986 4+3 CORVETTE
1986 4+3 CORVETTE's Avatar
Default 86 power steering pump problems
When car is cold power steering works worse, and it doesnt work at all at the begining of a turn then all the sudden works fine. It also works better or with no problems at all when its at higher rpms. I have no leaks and the fluid is real dirty. My question is is my pump bad or rack or both?
Old 09-26-2011, 11:33 PM
Deepa
Deepa's Avatar
whats the condition of the serp belt?
Is the pulley spinning on the shaft?
Old 09-26-2011, 11:48 PM
1986 4+3 CORVETTE
the belts in good condition ill check if its spinning im sure it is
Old 09-27-2011, 02:43 AM
DanZ51
DanZ51's Avatar
"Survey Says:" your rack is worn. 'Classic symptoms of what is called "morning sickness". The rack piston rides in an aluminum bore. Eventually the bore wears. Rebuilt units are steel sleeved and won't wear out on you.
Old 09-27-2011, 11:23 AM
pmihaltian
Slingshot
Support Corvetteforum!
pmihaltian's Avatar
However, you might consider flushing out your old fluid and replacing it with a good systhetic. The new fluid may work better for you. Here is a how to write-up.
Old 09-27-2011, 05:08 PM
Muffin
Muffin's Avatar
True-True but if it works it will buy you very little time. Plan now to replace the rack in the near future. The good news is it is a job you can do yourself and will not break the bank. The "How-To" has been well documented here.
To 86 power steering pump problems
Quick Reply: 86 power steering pump problems
