LT4 Lifter Noise
Old May 2, 2002 | 08:38 PM
John Ruy's Avatar
John Ruy
Default LT4 Lifter Noise
Last week after my 150 mile weekly commute. I pulled into the garage and heard an awful clattering noise, at idle only. After much investigation I decided it was either too much octane booster hammering :smash: my pistons or lifters. :confused:
So I changed oil and used some prolong additive. Drove the commute on Monday and did not use octane booster, filled up with Chevron 92 as usual. That week it continued and was begining to sound like a singer sewing machine at idle. :( Deffinitely lifters. I was getting desperate, so I stopped into a Kragens and bought some Resoline additive. It claims to eliminate lifter noise.
It worked!!! :eek: Now I am worried, with 85K on this LT4
I checked My manuals and they say there is no adjustment for the 96 C4. :chevy GMs infinite wisdom.:mad
Can the LT4 roller rockers be adjusted? Should I go to 20/50 Mobile One? Do I need to replace lifters or cam? Anybody got any bright ideas? Thanks :)
Old May 2, 2002 | 08:41 PM
Patrick96LT4's Avatar
Patrick96LT4
Cruise-In II Veteran
Default Re: LT4 Lifter Noise (John Ruy)
Both my LT4 cars, one had 19k miles, one had 11k miles.
Both had noisy fuel injectors.
Both had noisy clutches (noticed it got quieter when I put the clutch in).
I just stopped worrying about every tapping noise under the hood.
:D
Old May 2, 2002 | 08:46 PM
John Ruy's Avatar
John Ruy
Default Re: LT4 Lifter Noise (Patrick96LT4)
I would agree. But this could be heard across the parking lot by those who don't know. :crazy: I'ts the Resoline that's got me wondering. :confused:
Old May 2, 2002 | 11:52 PM
vettedave's Avatar
vettedave
You may have worn cam lobes. At 85 K it isn't inconceivable.
Check for loose pushrods with the valves closed.
:smash:
Old May 3, 2002 | 12:16 AM
tarheelracer's Avatar
tarheelracer
Default Re: LT4 Lifter Noise (vettedave)
At first I was thinking it was your injectors but you shouldn't be able to hear those across the parking lot.
Old May 3, 2002 | 01:04 AM
John Ruy's Avatar
John Ruy
:smash:
If they are loose, is there a way to adjust the lash?
Are we talking replacement?
Old May 3, 2002 | 08:24 AM
RichS's Avatar
RichS
The LT4 rockers are non adjustable. Pull the covers and re-torque the nuts, and check for any with too much play. If a nut loosened up it will make the loud noises. Also if there is alot of play in one you may have a lifter going bad.
Old May 3, 2002 | 10:12 AM
Goody's Avatar
Goody
Default Re: LT4 Lifter Noise (RichS)
Yeah, you might have pulled a rocker nut loose or worn something else out beyond limits. That thick honey stuff you use only masks the problem for a little while. Get a mechanics stethoscope and you might be able to narrow it down to one side or the other to save some work and time. You can touch it to the top of the rocker arm studs to hear which one is the loudest when the valve cover is removed. Good luck... :seeya
Old May 3, 2002 | 11:20 AM
John Ruy's Avatar
John Ruy
Default Re: LT4 Lifter Noise (Goody)
:cheers: THANKS...
Looks like I had better get the wrenches out this weekend. :sad:
Wouldn't want to let it go without a look see. :seeya
Old May 3, 2002 | 01:17 PM
Timmy!'s Avatar
Timmy!
If after everything you still can't find the "Tapping" noise, pull the oil pan and check those rod bearings - I just went through a similar scenario and it wound up being bearings :eek:
To LT4 Lifter Noise
