Tps low volts
Old Sep 29, 2011 | 07:57 PM
WOODY 87's Avatar
WOODY 87
2nd Gear
Default Tps low volts
1987 5.7 tpi. My tps reads .68 atfull stop& only4.0v at wot.can i adju.st this?& will it effect my maf sensor. Ive cgot code 34 but it tests out good. This is my 1st vett. & im kinda rusty. Any help would be helpful
Old Sep 30, 2011 | 03:59 AM
rodj's Avatar
rodj
Originally Posted by WOODY 87
. My tps reads .68 at full stop
That is way high ; should be .54 at idle.
Slightly loosen the 2 screws holding the TPS and rotate until you have correct reading.
. My tps reads only 4.0v at wot.
can i adjust this?
No , none of mine read over 3.2V and engine runs fine.
Old Sep 30, 2011 | 04:41 PM
WOODY 87's Avatar
WOODY 87
2nd Gear
thanks ill try that
To Tps low volts
