adjustable throttle position sensor
Old May 3, 2002 | 01:44 AM
97Supra's Avatar
97Supra
Default adjustable throttle position sensor
I just got through installing an adjustable throttle pos. sensor. Unfortunately I lost the paper that told me what the voltages should be. I know that WOT voltage should be in the 4.5 area but I can't remember what it should be at idle. Anyone know? Also, no matter how dramatically I move the new sensor, I can only get to 4.3 at WOT....and if I set it there, I'm pretty sure the voltage for idle will be off. Anyone have any suggestions?
Thanks,
Jason
Old May 3, 2002 | 02:25 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: adjustable throttle position sensor (97Supra)
I didn't think the adjustable unit worked after '90.
On the L98 you set the base idle voltage to 0.65Vdc safely; the ECM will throw the code above 0.67Vdc. My method of adjustment for a L98 is on my site.
A scan tool will of course tell you if the ECM is going open loop under WOT operation.
Old May 3, 2002 | 07:18 AM
vettmanlt4's Avatar
vettmanlt4
Default Re: adjustable throttle position sensor (65Z01)
The 90-96 TPS are non-adjustable and are auto-zero'd in the engine computer. At idle it should read o.54Vdc and 4.5-5V at WOT.
Old May 3, 2002 | 09:10 AM
SonnyinVA's Avatar
SonnyinVA
Default Re: adjustable throttle position sensor (vettmanlt4)
you can use the 89's adjustable TPS on the 90-96 and as long as you set it below 1.0V at idle it'll auto zero and i haven't gotten a code yet... the most i've gotten is 4.6V on mine at WOT and my friends 90 got almost 4.8 but then was way off at idle.
Old May 3, 2002 | 09:29 AM
LPDesRoche's Avatar
LPDesRoche
Default Re: adjustable throttle position sensor (SonnyinVA)
You can only use the 89 and below adjustable style on the 85-91's the LT1's take a different style all together. For some reason in 90 they switched it to a non adjustable unit on the L98's. You can either make the holes larger or buy the 89 and below unit.
Old May 3, 2002 | 09:32 AM
SonnyinVA's Avatar
SonnyinVA
Default Re: adjustable throttle position sensor (LPDesRoche)
right, i didn't mean thru 96, sorry for the confusion
Old May 3, 2002 | 02:53 PM
97Supra's Avatar
97Supra
Hi. Yeah, the stock unit is non-adjustable, but Mid America sells an adjustable replacement (said to help smooth idle which is why I got it) specified for my model year. Unfortunetly I can not get it past 4.3 v. at WOT. At that voltage, am I losing performance? Any ideas how to get it up to 4.6?
Thanks,
Jason
To adjustable throttle position sensor
