Distributor Question
Old Oct 2, 2011 | 10:07 PM
97VetteDan's Avatar
97VetteDan
Default Distributor Question
Will a distributor out of a Carbureted 396 Chevy motor work in a 350 fuel injected Corvette motor?
Old Oct 2, 2011 | 10:28 PM
rodj's Avatar
rodj
If you have a carb
Old Oct 2, 2011 | 10:30 PM
97VetteDan's Avatar
97VetteDan
Originally Posted by rodj
If you have a carb
What do you mean?
Old Oct 2, 2011 | 10:41 PM
rodj's Avatar
rodj
What do you mean?
Carb dist for carb engine.
EFI requires a computer controlled dist .
Completely different dist; has a plug with 4 wires coming out of base
Old Oct 3, 2011 | 08:04 AM
WW7's Avatar
WW7
I just bought one of these for my 383 motor..http://www.summitracing.com/parts/DUI-12611BK/ .. This has electronic controlled timing . Like rodj says, carb uses a distributor for carbed motor...If your looking for a distributor Im going to be selling the one I pulled from my motor on here shortly, complete with a almost new cap and rotor, Ignition control module, brand new Accel mellonized steel gear shimmed to proper specs, and coil for around $80.00 .. It works perfectly and has 2 month old parts..Just drop it in and drive.. ...WW
Old Oct 3, 2011 | 09:11 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
THAT is a good deal.
To Distributor Question
