Codes 34 and 44
As spring rolled into summer the car started experiencing idle issues, surging at idle and rough running at low throttle with intermitant service engine soon light. I tried resetting the IAC but it didnt seem to help. The issues would occur mainly when the motor was warm and in closed loop
With summers being busy I lived with it, but when when the car stalled pulling out of a parking and I got a hard code (always on) I figured I better start diagnosing, luckily the car refired after a few try's. It would fire and stall within a couple of seconds.
I shorted the ALDL terminals and got codes 34 and 44. Using the FSM
and the search history on the CF, my first step was the clean the throttle body, IAC valve, check TPS, and reset IAC. The thottle body and IAC were dirty but not bad. The TPS was a little low .50V. I started the car and still had a hard code 34 and 44.
The FSM doesnt say much concerning the MAF relays, but it seemed to be a major item to check on the forum. I replaced both relays this weekend, started the car on the hard code was gone..... I drove the car a few miles and it seemed to run well.... until it got warm. The idle issue came back and I got the intermitant code. I pulled back into the garage and checked the code history, 44 was back.
So what next... all indications were leaning to a bad O2 sensor, a couple of years ago I put a new O2 sensor in just for the heck of it, their cheap, could that be it? I took out the O2 sensor and cleaned it with degreaser and reinstalled. Same thing happened, intermittant code 44 and crappy idle and surging at operating temp.
I went down and bought a new O2 sensor, installed it and all is well, runs and idles good.
I read the instuctions on the new O2 sensor and it say's don't use cleaner on them....dah....So, did i have a couple of things going on at the same time..bad MAF relays and O2 sensor.... I dont know... I'm still not sure either would have caused the car to stall in the parking lot.
I'm wondering, I've got a flat tappit car and use break in oil with high zinc. I've read that the high zinc is hard on O2 sensors.
Hope this helps some poor schmuk in the same boat i was in.
Check you wire and clean it if necessary. You might have to change the valve cover gasket if you oil is generated from this area.
