Dist Timing-1987 C4
Old Oct 3, 2011 | 10:32 PM
fcable's Avatar
fcable
Default Dist Timing-1987 C4
What is the intial timing for the dist on a C4 (1987)? All the service manual says is "per the sticker on the radiator cover", which has long since gone.
Old Oct 3, 2011 | 10:47 PM
rodj's Avatar
rodj
6 degrees with EST (timing ) connector disconnected
Don't forget to reconnect after adjusting timing
Old Oct 4, 2011 | 12:05 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Many of the early C4's have experienced timing mark movement on the dampeners.
You might consider checking TDC on the marks if your timing seems off.
Old Oct 4, 2011 | 05:41 PM
Muffin's Avatar
Muffin
If my FSM is correct you will also need to clear the code set by disconnecting the EST.
To Dist Timing-1987 C4
