1991 Fuel Injector Problems
Old Oct 7, 2011 | 01:38 PM
User261483's Avatar
User261483
Default 1991 Fuel Injector Problems
My 1991 is running rough at idle where it used to be smooth as glass. I changed the plugs and wires, even changed out the C02 sensor. Now I'm told that the E10 fuel that is being sold has caused my fuel injectors to go south in a big way. Anybody else having problems with original injectors going bad because of the new fuel? Thanks for your help or input in advance.
Old Oct 7, 2011 | 01:54 PM
navy_vette's Avatar
navy_vette
The stock Multec injectors don't like ethanol at all. They aren't bad injectors, they just weren't designed for this type of fuel. If they are stock injectors, I would vote that it is part of your problem.
Talk to Jon at FIC. You will find something that you will like. I haven't heard a single bad thing here about FIC.
Old Oct 7, 2011 | 02:00 PM
aklim's Avatar
aklim
Dump them for Bosch 3s and have them tested ever 2 or 3 years. Stock Multecs weren't the best
Old Oct 7, 2011 | 05:09 PM
Calderone's Avatar
Calderone
Fuel Injector Connection, LLC
4966 Wade Valley Way
Cumming, GA 30040
Tel: 770-888-1662
Jon at FIC http://fuelinjectorconnection.com/shop/
SEND FICINJECTORS A PM HERE
This video might be useful to you as well
Let us know !
Old Oct 7, 2011 | 05:50 PM
RLG's Avatar
RLG
Ohm check the injectors, if they don't read 14.2 or something close you need to replace, and as indicated call Jon, That's what I did.
Old Oct 7, 2011 | 06:17 PM
aklim's Avatar
aklim
I believe all it will tell you is resistance. Even if everything is clogged up beyond what the ECM can adjust to, it might still ohm out fine. I haven't had to ohm check an injector. Ever 3 or 4 years, I just send them off for testing and cleaning to Jon or RC Engineering, etc, etc. Let them check it out and if it comes out good, fine. If not, they fix. Either way, it should be a PM item for every few years to have it cleaned and tested. Way more productive than an ohm test
Old Oct 7, 2011 | 08:41 PM
User261483's Avatar
User261483
Thanks again guys. I'll be taking it into the shop first thing next week. I didn't expect
so many replies so fast.
Old Oct 7, 2011 | 10:41 PM
aklim's Avatar
aklim
I wouldn't. I'd postpone the shop visit for a couple of weeks while you send your injectors off. I have been to quite a few shops and when they suspect something that has some link to the injectors, they want to replace them and not test them. I don't even think I have seen a shop besides Lingenfelters that has an injector flow bench.
Old Oct 8, 2011 | 04:10 AM
Cliff Harris's Avatar
Cliff Harris
Superior Automotive Engineering in Placentia, CA cleaned and flowed mine. They gave me a printout of before and after flow rates.
Old Oct 8, 2011 | 01:13 PM
RLG's Avatar
RLG
I had a miss when I bought my car and suspected the injectors as they were the original ones. I check the ohms as a quick way to determine if they were shorted because of the fuel we use. Two of them read 5.6 4.5 the rest were 16.2, I called Jon and ordered a set of his injectors. Fixed the problem.
Old Oct 8, 2011 | 03:19 PM
navy_vette's Avatar
navy_vette
The coils can go out on the Multecs and this is a common thing and it IS caused by using ethanol fuels. However, clogged injectors will ohm out correctly and I think a few people forget about that. They will ohm out fine, but will be the problem.
The injectors can be rebuilt for cheap. However, I would go with the Bosch III design. They are simply better built and the atomization is a hell of a lot better. You will get a much better fuel burn and therefor, more power. I just ordered a set (24lb since I dropped a ZZ4), but you should go with the 22 lb injectors since it's stock. If you put even 24 lb in there, you'll need a tune to run properly. I learned the hard way and now my car is RICH. With new injectors, I can clean the carbon off the exhaust and be back to a nice clean system.
Old Oct 8, 2011 | 03:22 PM
aklim's Avatar
aklim
Have Jon check it every few years to clean and test.
To 1991 Fuel Injector Problems
