Staggerd?
Old Oct 8, 2011 | 12:55 PM
motor city dave's Avatar
motor city dave
St. Jude Donor '16
Default Staggerd?
Hey guys, I have a 95 lt-1. Im going to put a mini starter in it fron Summit. They want to know if it has staggerd bolt pattern? Got under there looks like bolts are straight across from each other but 1 looks longer than the other. kinda lost Thanks for any info.
Old Oct 8, 2011 | 06:05 PM
TJM's Avatar
TJM
Outbound one is shorter. Be sure to check the bolts when you install.
Summit is great, but they are big and a little stupid. Unless you have a ZR1 the MINI starters are pretty much the same. Four vertical holes in the Mounting block make it pretty darned universal.
They may have meant did you want "clocking". " Clocking " allows you to rotate the starter position into a number of different orientations.
The aluminum block that the starter bolts too on a mini will have about twelve holes in it, that allow the movement.
Oh yeah.... ... be sure to check the bolts lengths. I bought one and they had the wrong bolts. 1/4" too long [ with the shims in ].
Potentially disastrous if to short or too long.
Just saying..............
Old Oct 8, 2011 | 07:49 PM
motor city dave
St. Jude Donor '16
Thanks TJM, I put Headers on didn't think bout the heat thing. Think i roasted the solenoid.
Old Oct 10, 2011 | 03:47 PM
Mikky89's Avatar
Mikky89
The staggered bolt pattern refers to the bolting to the block. Earlier sbcs and bbcs with 168 tooth flywheels had a "staggered" bolt pattern on the starter. There were 3 holes drilled in the block, where the 153 tooth flywheels used the inline and the 168 tooth had the staggered.
To Staggerd?
