1994 DTC Code 29 EAS Electrical Fault
Old May 3, 2002 | 04:43 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default 1994 DTC Code 29 EAS Electrical Fault
Anybody have a clue what this is? I looked in my manual under the ECM codes but it did not list a 29 in my '94 Service manual. Should be in section 4.1 I believe.
Thanks for any help as I can't even think if what the EAS part could be.
Old May 3, 2002 | 05:51 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: 1994 DTC Code 29 EAS Electrical Fault (Vette92)
DTC 29 is for the Secondary air injection pump circuit. The PCM is detecting the wrong voltage. Check all of the connections, etc.... :cheers:
Old May 3, 2002 | 06:15 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: 1994 DTC Code 29 EAS Electrical Fault (lou sylvestri)
Thanks. I will recheck a few connections. I did remove my AIR pump recently so I may not have got all the connections back on.
Old May 6, 2002 | 02:31 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
I am not sure why my '94 book did not list the code 29, but it turned out to be a connection at the AIR pump that I had missed when I put it back in.
Thanks again.
Chris
To 1994 DTC Code 29 EAS Electrical Fault
