Fuel Tank Wiring
Old Oct 10, 2011 | 12:46 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Default Fuel Tank Wiring
On my 88 there is a white plastic cube just below the tank mount that all 3 wires pass through. Does anyone know what it is and is it necessary? It is not shown in the FSM. Thanks
Old Oct 10, 2011 | 02:06 PM
SunCr's Avatar
SunCr
Don't know what you mean by a "cube". There is a connector to the forward harness but that's in the passenger compartment. '89 has an extra wire to nowhere at the pump which is for the LT5 that never made it into production (until '90). All tanks need a ground wire to the tank to keep static electricity from blowing you up when you fuel it. And GM (and all the others) uses various gadgets to keep the harness secure so that it doesn't flop around and abrade the insulation for the same reason.
Old Oct 10, 2011 | 08:43 PM
SunCr's Avatar
SunCr
Now that you've posted a picture - or that it's now showing on my computer - that looks like some sort of insulator to secure the harness to the tank or some support. As I noted, you don't won't it flopping around and abrading the insulation.
Old Oct 10, 2011 | 09:39 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
I guess you don't know either, but thanks anyway.
To Fuel Tank Wiring
