Sensor question
Old Oct 11, 2011 | 05:12 PM
jadedvette's Avatar
jadedvette
Default Sensor question
Can someone tell me what are the two sensors in the front of the intake manifold? One has like a fuel injector plug on it, and the other has a two wire plug. Thank you, Joe
Old Oct 11, 2011 | 06:41 PM
don hall's Avatar
don hall
Default sensors
The following link identifies C4 sensors and locations:
http://www.corvettephotographs.com/c...nformation.htm
Old Oct 12, 2011 | 02:21 AM
vetteoz's Avatar
vetteoz
2 wire sensor circled is the Coolant Temp Sensor for the ECM.
Brass unit to the left ( with inj plug ) is the cold start switch to operate the cold start injector used on 85 -88 TPI
Old Oct 12, 2011 | 03:34 AM
Cliff Harris's Avatar
Cliff Harris
One is the CTS - Coolant Temperature Sensor. It connects to the ECM.
The other is the cold start switch (the one with the fuel injector looking connector). It turns on the cold start injector while the engine is cranking. It's a thermostatic switch and opens after 8 seconds of cranking or when the coolant is hot.
Old Oct 12, 2011 | 06:27 AM
jadedvette's Avatar
jadedvette
Thank you, I thought the one had something to do with the cold start but didn't know what. Joe
Old Mar 12, 2012 | 02:04 PM
myfunz's Avatar
myfunz
Old Mar 12, 2012 | 06:51 PM
rodj's Avatar
rodj
Originally Posted by myfunz
Why?
Post is three months old and the question has been answered
To Sensor question
