93 Vette SYS help
Old Oct 12, 2011 | 12:12 PM
tim1's Avatar
tim1
Default 93 Vette SYS help
Fixed a couple issues yesterday, and now I have SYS flashing on the dash. I read that if I ground the "G" of the Data Link Connector, turn on the IGN that the CCM will display the DTC's. Does that sound like my next step to identify this new problem? Started a new post to try and get some input on this before I dive in head first and make a mess out of it.
Old Oct 12, 2011 | 01:52 PM
c92vette's Avatar
c92vette
I would disconnect the battery for several minutes to reset the system. Then if the "SYS" light came back you can pull the codes yourself or try going to Autozone and see if they can do this for you.
Good luck
Old Oct 12, 2011 | 02:22 PM
freedog81's Avatar
freedog81
I believe autozone and the like only do diagnostics on obd2 vehicles
Old Oct 12, 2011 | 04:11 PM
STL94LT1's Avatar
STL94LT1
Test your battery charge.
To 93 Vette SYS help
