FX3 replacement
Old Oct 12, 2011 | 01:48 PM
ndanl's Avatar
ndanl
Default FX3 replacement
what do you recommand as a fx3 replacement, I want something sooooft for bumpy roads, the fx3 are way to sport/hard for the city roads here
Old Oct 12, 2011 | 01:57 PM
c92vette's Avatar
c92vette
The FX3 is an adjustment shock system that you can adjust the ride with. The suspension is normally stiff, as expected, for a high performance vehicle. I think the best you can do is set the FX3 to Touring and go with it.
Old Oct 12, 2011 | 04:56 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Old Oct 13, 2011 | 02:20 AM
ndanl's Avatar
ndanl
even in Touring the suspensions still not soft enough ...
Old Oct 13, 2011 | 05:46 PM
RLG's Avatar
RLG
pull them off and replace with KYB
Old Oct 13, 2011 | 10:16 PM
93Rubie's Avatar
93Rubie
FYI, at low speeds touring has almost zero dampening. The problem is not the shocks (unless they are totally toast and wore out) the problem is your rough roads combined with a 91's stiff springs.
See the chart near the bottom of the page, it is the one on the left.
http://www.corvetteactioncenter.com/...fx3/index.html
Old Oct 13, 2011 | 10:54 PM
quickcat's Avatar
quickcat
Old tires make for a harder ride too. If your tires are about due consider getting the softest ride you can find. Your tire shop or TireRack.com might be able to help. I would guess that all seasons might be best here.
Matt
Old Oct 14, 2011 | 12:18 PM
93Z07's Avatar
93Z07
If you want a softer ride then change cars not suspension.
Old Oct 14, 2011 | 12:49 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
What year C4? If you have Z51 springs they are what is causing the harsh ride. The FX3 shocks in Touring mode are not very stiff. My '90 with base springs and shocks turned down rides like a Cadillac. I manually turned the shocks to full stiff and it felt a little stiffer, but not much.
To FX3 replacement
