Tuner Cat help needed for DA2 Def. file (92 vette)
I am trying to do some programming and don't know what the tables actually represent. I have two main problems. In open loop the car idles too rich. If the car is warm and I start it, it will barely idle until it goes into closed loop. The second problem is, I need more fuel at WOT. Can anyone tell me the tables I need to be most concerned with? I have helped with other cars, but this def. file confuses me.
Re: Tuner Cat help needed for DA2 Def. file (Marcho Polo)
I don't have a WOT table, but I have a PE table. I believe that they are the same.(I think) Basically I don't understand wich table to use. I have a PE %change air/fuel vs rpm table and a PE % change air/fuel vs coolant temp. When does the computer use the respective table?
If not, the corrected VE tables are where you need to start to get the idle under control. If so, you can move on to playing with spark and start-up enrichment.
