vibration during acceleration
Old Oct 16, 2011 | 06:42 AM
Mohammed_z's Avatar
Mohammed_z
Default vibration during acceleration
it just happens when the AC is on .
at 2500-3000 RPM
Old Oct 16, 2011 | 06:44 AM
navy_vette's Avatar
navy_vette
Pop the hood, start up the car and run thru the RPM range manually. The A/C mount will probably start to vibrate on it's own. It might be the clutch.
Old Jun 17, 2012 | 04:58 PM
Mohammed_z's Avatar
Mohammed_z
Took the car to a electrician , he said the ac clutch is fine.
He told me the problem might be because of the tensioner. !!
if there is a problem with the tensioner , it should be there while the ac is off ?? why it only happens when ac is on !!!!
Old Jun 17, 2012 | 07:33 PM
Aqualoo's Avatar
Aqualoo
You're not alone, and don't replace your tensioner. I'm one step ahead of you.
Old Jun 17, 2012 | 07:36 PM
1986coupe's Avatar
1986coupe
Check "all" of the bolts at the ac compressor. Make sure that they are all tight. Check the belt tensioner to make sure it is tight.
Also, why an electrician for an ac clutch? It engages with electricity but its function is physical. If the clutch has physical problems it will engage but could slip and cause vibrations. Check again.
Old Jun 17, 2012 | 08:13 PM
Mohammed_z's Avatar
Mohammed_z
Let me know when you solve the problem , I don't want to waste money on something working fine !!
Do I need to remove the belt to check the tensioner tightness ?
The air is cool inside the car , clutch engages , the guy told me if the clutch is bad the air won't be cool !!
I'm not sure how can I know if the ac clutch is slipping !!
should I replace it ?
Old Jun 17, 2012 | 08:18 PM
Aqualoo's Avatar
Aqualoo
Honestly I hardly ever run A/c anyway and it's done it ever since I bought the car. Also when I first bought the car the system was completely discharged and had to be charged several times before the seals would keep the refrigerant in and I thought the vibration was a dying compressor due to the lack of lubrication for however long it went without refrigerant.
Old Jun 17, 2012 | 08:25 PM
cv67's Avatar
cv67
St. Jude Donor '05
When tensioners go bad you can usually tell it will make a loud rattling/bearing type noise.
Old Jun 17, 2012 | 08:30 PM
Mohammed_z's Avatar
Mohammed_z
I can't drive without AC on and full ac , today's temp was 113F
actually I barely drive the car in the summer , I live in a hot humid area. Which sucks this time of year , and thats why I'm preparing for some online orders.
I need to check that.
Old Jun 17, 2012 | 08:33 PM
leesvet's Avatar
leesvet
Tensioners DO wear out but its a slowly increasing squeek or chirping vs a rattle or banging noise. More like what a belt would sound like...
IF you rev the motor and can SEE the tensioner vibrate ANY with or without the a/c on...replace it. A good tensioner will NOT vibrate or even jiggle as rpm goes up and down...it should smoothly move a little bit to compensate for the added drag on the belt.
A REAL tensioner can cost $150 locally...cheapo remans $90 or so.
You get exactly what you pay for in this dept.
Old Jun 17, 2012 | 08:36 PM
Aqualoo's Avatar
Aqualoo
Originally Posted by Mohammed_z
I can't drive without AC on and full ac , today's temp was 113F .
Don't worry I know what you mean I've had to deal with that same heat when I was over there. Your A/c still works though, right?
Old Jun 17, 2012 | 09:10 PM
csthews's Avatar
csthews
I am having the same issue. I've tried revving the engine in the driveway with the clutch engaged, no vibration. It only vibrates when moving down the road and the clutch engaged.
I read on an older post here that the vibration can be the result of a missing bracket that goes from the back of the compressor to the header. This bracket is oftentimes removed and left off if headers are installed. The PO had shorty headers installed and this bracket is missing. The header install was really crappy so I went back with stock. Now I am looking for the bracket.
Old Jun 18, 2012 | 05:58 AM
Mohammed_z's Avatar
Mohammed_z
It works but I don't want to drive the car with vibration that leads to something more serious.
It can't be because of the bracket.
Nothing changed in my car , the problem suddenly came up.
maybe one of two :
1- AC clutch
2- Tensioner
I'll check the tensioner when I go home.
Old Jun 22, 2012 | 07:44 PM
STL94LT1's Avatar
STL94LT1
Did you remove the A/C braces when installing headers?
Old Jul 12, 2012 | 11:49 PM
csthews's Avatar
csthews
Was this problem ever resolved and, if so, what was the solution?
Old Jul 13, 2012 | 03:11 AM
Mohammed_z's Avatar
Mohammed_z
The problem happened before touching the headers , But I know there is something missing , When I compare pics , I think the braces are not there.
No , just wasted time and money. Still in the progress of troubleshooting the cause of this.
I changed the tensioner pulley and still the same. Will be changing the AC compressor clutch and see if it works
Old Jul 13, 2012 | 12:25 PM
1fatcat's Avatar
1fatcat
Mine does this too. Only with A/C on and at about 2300 rpm. It does it while accelerating or decelerating and always at 2300 rpm. Weird. It vibrates the whole car all the way back to the tail pipes. I thought it might have been a u-joint at first, but it does it at a complete stop too.
I also have headers, that seems to be something we all have in common with this problem...no?
I have not checked to see if that compressor bracket is on mine or not.
To vibration during acceleration
Old Jul 14, 2012 | 02:22 AM
Mohammed_z's Avatar
Mohammed_z
Let me know when you find the problem , the vibration sucks and the weather is hot here.
Also take some pics of the bracket.
Old Jul 15, 2012 | 05:44 PM
csthews's Avatar
csthews
The FSM shows a brace that appears to go from the back of the compressor bracket and bolts on to the header. I don't have this brace on my car. I've looked at a number of LT-1 pics here and I don't see it on any of them either.
Old Jul 15, 2012 | 05:57 PM
STL94LT1's Avatar
STL94LT1
Edit: Both a/c braces can be used. It was the alternator brace I had to eliminate with the header install. See next post for updated pic.
