'88 Digi dash/electrical problems...help please
Old Oct 16, 2011 | 04:15 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default '88 Digi dash/electrical problems...help please
I've been having trouble with the dash going very dim/out and the turn signal ligs coming on==symptom of grounding issues.
I've opened the dash, cleaned conenctions, examined both PCBs, insatlled new bulbs & sockets, etc. Still the problem persists.
I just ohmed out the D1,D2,D3 connections to batt gnd and get 4-5 Ohms resistance. I think I should see 0.1 Ohm or so; anyone with experience here have an opinion??
Old Oct 16, 2011 | 04:54 PM
tunedport85inject's Avatar
tunedport85inject
As usually, it comes usefull again Batee and his site http://www.batee.com/corvette/index.htm i think you know about it,my atary works fine for some months then goes dark for some months again,i performed all batee advices...no way, but i think, when it comes alive again,if now is alive then it isn't broken...i give 3 new ground wire to it,like batee explains,the same...
Old Oct 16, 2011 | 05:19 PM
65Z01's Avatar
65Z01
I'm rereading his advice and may do some of the soldering he recommends.
Regarding the three ground connections, I can do those but aren't satisfied with the ground points available under the dash??
Old Oct 16, 2011 | 05:44 PM
BroCorvette's Avatar
BroCorvette
My attached facebook album has pics of when I had to fix my digi dash. I had to replace 2 grounding jumper wires and removes someone previous failed attempt at fixing it (the fuse).
Album
Bates is what I went off of too so you should find your problem without fail.
Old Oct 16, 2011 | 06:56 PM
HlhnEast's Avatar
HlhnEast
Your right the ground should read about nil. If your signal lights are constantly lit its a pretty good indicator of bad grounding. You can tie all three together and carry it to a known good ground. I drilled a 1/8" hole in the firewall next to the big harness connector in the left side footwell and carried the new ground wire to the frame to battery ground then dabbed silicone over the wire and hole.
Old Oct 16, 2011 | 07:00 PM
BroCorvette
Wow yeah that would solve the grounding problem. With the flickering your probably not going to see where its broken very easily. My guess is the solder to one of the pins is cracked, or like mine one of the connector pins actually cracked in half and I couldn't tell till I tried to move it. The white connector that has the connections between the two PCB is the area of like 90% of the failures.
Old Oct 16, 2011 | 07:21 PM
HlhnEast's Avatar
HlhnEast
Yeah the pin problem was actually the culprit of my no light issue. I soldered a wire on each of the PCB's at the + pin and jumpered around the bad part. Still working great.
Old Oct 16, 2011 | 11:46 PM
65Z01's Avatar
65Z01
At this point I'm going to do all the batee PCB "fixes" as well as to run a good ground wire through the firewall.
Guys, thanks for the feedback & advice...
Old Oct 17, 2011 | 11:22 AM
engle1147's Avatar
engle1147
If the interior of the car has been exposed to super high humidity conditions/levels (or it just got wet) give it a few days or a week to dry out on its own before you jump in and start to "fix" things....those connections inside the cabin are not the most electrically "sound" things.
Old Oct 17, 2011 | 01:21 PM
tunedport85inject
extrema ratio you'll send your cluster to a service shop...some bucks for a pro work
Old Oct 21, 2011 | 01:41 AM
65Z01's Avatar
65Z01
The good news is that I found one of the inter-board connectors a bit burned so I hit the pins with some new solder and the dash has been working solidly for over a day during several "test drives"...
I didn't run the new ground from battery through the firewall; at least not while the display is working well.
I'm now in the process of reassembling the dash; hope to wrap it for the season.
Old Oct 21, 2011 | 09:55 AM
87Vetteowner's Avatar
87Vetteowner
I love the Atari Dash . One reason I love my 87 IT is also a common thread here.
It is hard to believe, but the newest Atari dash is 22 years old now. Sheesh..
But I was lucky a couple of years back and found a guy local to fix mine. He had to do a lot of resoldering and replaced a couple of parts. But one thing he found were bad grounds.
Either later today or tomorrow, I have to replace one of the back lights in my dash. I know it isnt a hard job, just one that takes a bit of time.
Old Oct 21, 2011 | 10:37 AM
engle1147's Avatar
engle1147
FYI: there is a super hard to see/locate non serviceable thermal style switch/component that is inline with the main cluster ground. The component is located right in with the bundle of wires as soon as they exit the firewall plug (inside the cabin). The purpose is this inline component is to "open" the circut when cabin temperature is well below freezing - this prevents the LCDs energized to prevent panel damage. The reason I mention this is because they can go bad/intermitant and cause problems such as your describing.
Old Oct 21, 2011 | 04:17 PM
65Z01's Avatar
65Z01
...I have to replace one of the back lights in my dash. I know it isnt a hard job, just one that takes a bit of time.
I found it a real PITA to change those bulbs from the front so I installed new bulbs while all were out.
Yes I found that switch and jumpering it made no difference; it's recommended by Gordon Killebrew (in his book on the digi dash) to simple leave those contacts jumpered but I replaced the module...for now.
Today I installed the dash pad, all bezels, the hush panel and retested the illumination...all is AOK...thanks to all again.
To '88 Digi dash/electrical problems...help please
