Powder coated Dana 44 case
Old Oct 16, 2011 | 10:05 PM
lees02ws6's Avatar
lees02ws6
Default Powder coated Dana 44 case
After reassembling the case the differential makes noise on acceleration (whirring), and howls.
Did the powder coating do something to the case? All new bearings and seals were installed.
Old Oct 16, 2011 | 10:13 PM
87 vette 81 big girl's Avatar
Was a gear pattern tooth test performed to confirm drive & coast patters were right on money correct ?
Powder coating the dana 44 case would not affect it at all.
Old Oct 16, 2011 | 10:26 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
If it is noisy, the gears migh have been installed incorrectly. Did you DIY your differential?
Old Oct 16, 2011 | 10:32 PM
lees02ws6's Avatar
lees02ws6
I didn't the diff was disassembled by the local GM dealer, powder coated by a local shop, and then reassembled by the GM dealer.
The dealer is claiming the ring and pinion are worn.
I spoke to someone at Corvette Parts, and they claim that even if the the diff were reassembled with the shims, etc. in the same places the heat from powder coating could have affected the alignment of the ring and pinion.
What places would you recommend that could give me an honest diagnosis of what is wrong with this thing? Has anyone ever had a rebuild done by corvette parts online?
Old Oct 16, 2011 | 10:51 PM
Don't scrap your C4 dana 44 or rip it down apart just yet.
Need to perform a gear pattern test.
Need GM gear marking compound or similar.
Prussion Blue from Napa will work OK too.
I rebuild all rear diffs.
Including C4's.
Brian
Old Oct 16, 2011 | 11:27 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
http://corvettepartsonline.blogspot.com/
If its the same guy, not sure you want to be dealing with him.
Old Oct 16, 2011 | 11:41 PM
I had a 1970-1/2 Trans Am - Camaro 12- bolt Eaton 8-7/8" rear housing powdercoated in the past.
Had it powdercoated Gloss Black by Sun Valley Powder Coating in Bloomington, Illinois back in 1997.
Was going to use it for my 70-1/2 T/A.
I ended up selling that rear to an old friend with a 1981 Camaro.
He ran low 9's on it.
Used a 9310 nickle Richmond Gearset for it.
Moser 33- spline axles & matching spool.
4.10 gears.
He street drove his car back then also.
He switched a Strange aluminum 3rd member 9 inch.
Running mid 7-s with a Big Block Chevy & Pro- Charger blower.
Powder coating never hurt that 12- bolt housing.
Actually had it powder coated twice.
1st time around there was blemishes in the finish.
I requested it to be stripped clean & re powdercoated.
2nd time around, it came out flawless.
It was in the baking oven 2 times.
That 12 - bolt rear setup perfect.
Picture perfect Drive & Coast patterns.
Never tweaked the housing or sprung it from the baking heat operation(s).
BR
Old Oct 16, 2011 | 11:47 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Another great deal by the stealership. C6 owners hate the stealership with passion.
I bet "the guy" just put all components in together without dialing up, backlash etc. Lets hope he, at least, used a torque wrench.
Why did you powder coated the pumpkin? Are you into Vette Car Shows?
Old Oct 16, 2011 | 11:51 PM
I honestly can not say........
He needs to perform a Gear pattern test.
Then post results here on c4 with very high quality pics for me to observe close up.
Many tell tale signs of what is wrong.
I know exact from looking 1st hand.
Old Oct 17, 2011 | 12:23 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
If its the same guy
RUN, RUN now and never look back.
Old Oct 17, 2011 | 09:19 AM
lees02ws6's Avatar
lees02ws6
Will do, and thanks to the other posters for the heads up about that vendor. I will steer clear.
It's not a vette, it's yet another non-vette, running vette suspension. So, appearance is an important part of the package.
Old Oct 17, 2011 | 12:19 PM
lees02ws6's Avatar
lees02ws6
It is the same guy, although he said his name was "Callie". In any case you saved me a big headache. I searched on this board, and found numerous complaint threads.
Thanks again.
Found this too
http://florida.arrests.org/Arrests/Carl_Shuhi_1270707/
Old Oct 17, 2011 | 05:47 PM
PLRX's Avatar
PLRX
2017 C4 of Year
who is this dude?
Old Oct 17, 2011 | 05:55 PM
lees02ws6's Avatar
lees02ws6
who is this dude?
Apparently that's Carl Shuhi of
CORVETTEPARTSONLINE.NET
VETTEPARTSONLINE.COM
VENICIAN VETTE PARTS
FLORIDA CALIPER MANUFACTURERS
FLORIDA PRECISION CALIPERS
Caliper 2000
He's apparently been the subject of many reports to Better Business Bureaus, and State Attorney Generals.
Old Oct 17, 2011 | 06:25 PM
AKS Racing's Avatar
AKS Racing
Just an FYI on some items posted above....
Powder coating a steel/cast iron differential is considerably different than powdercoating an aluminum D44 case. 5000 series alloy (and even 2014, less we mention the 7000 series) will definitely affect the strength due to the bake after the powder application event. Will it be enough to cause it to break immediately? Only time will tell.
The increased temps that aluminum experiences during such events not only causes a change in age, temper, and strength, but they may also cause things to "move" and tolerances to change. Not critically important in a large cast aluminum part, but much more important in a fully machined aluminum piece.
Old Aug 17, 2017 | 05:57 PM
BootzandI's Avatar
BootzandI
5th Gear
Default Carl Shuhi
I know a lot of corvette owners have been ripped off by Carl Shuhi and his girlfriend. If you want to send him a letter, his address is 124 SE 25th Ave Boynton Beach, Fl 33435
Originally Posted by Jonnymac
If its the same guy
Old Aug 17, 2017 | 05:59 PM
BootzandI's Avatar
BootzandI
5th Gear
Default Carl Shuhi
Yes, this is Carl Shuhi. He now lives at 124 SE 25th Ave. Boynton Beach, Fl 33435. Please feel free to send him a letter letting him know of your displeasure. Spread the news.
Caliper 2000
To Powder coated Dana 44 case
