I bought my 1991 vette about 3 months ago (from my brother who now has a C5) and it has had an intermittent "clattering" noise that seems to come and go at any temp but does sound a little louder when it is running warm. That's another question. Why does it run hot sometimes (the needle more than 3/4 to hot side) regardless of outside temp? My owners manual says a little pinging is normal and I've heard vette owners say that they just naturally run hot. Is that true?
These cars do naturally run hot. It's just the nature of the best.
About this clattering noise though. I know you said it doesn't matter for the temp, but any patters as far as RPM, how hard you are pushing the gas or maybe something about acceleration or deceleration? Where does the sound come from?
We also need year, engine type and what transmission you have.
The sound seems to come on at idle and light acceleration and goes away at higher RPMs. I notice it most when I give it very light throttle.
It's a 1991 with A/T and L98 engine
Pretty sure it's coming from the engine. Have not scaned for codes, but there is nothing coming up on the dash display screen as far as any kind of SES lights etc.
"Normal" temperatures on a Corvette are in the 200 - 230 degree range. It does have a 195 degree thermostat, so that's what you can expect. If it's higher than 230 on a regular basis, the prime suspect is trash between the condenser and radiator. It slips under the condenser and gets trapped in there. Sealing that gap is a good preventive measure.
I had a clattering noise that turned out to be loose exhaust manifolds, especially on cylinder #7. One bolt was sticking out about 3/8". I find I need to tighten them up once in a while.
I would start with the easy stuff mentioned above. To through the bolts when the engine is both cold and hot. Use a mechanix glove or welder's glove to keep from being burnt when it's hot.
Pop the hood, start it up and either have someone go through the RPM ranges while you are listening, or manually twist the TB. Try to find out where it is coming from as closely as possible. You might find something as simple as a bracket is loose or an exhaust bolt like mentioned above. It's all about narrowing down the location at this point.
