junk trans 700
Old Oct 20, 2011 | 02:57 PM
newoldvette's Avatar
newoldvette
4th Gear
Default junk trans 700
Can someone describe whats going on with my transmission? Every so often my trans acts as if it doesnt have a 2nd gear. Sometimes it just revs and other times it fine. Last week after coming to a red light, the car would not shift into 2nd gear. After I let of the gas and the rpms went down, I heard a clunk, the the car shifted normal all day.
what is the clunk noise
Old Oct 20, 2011 | 03:24 PM
383vett's Avatar
383vett
Check fluid level and tv cable adjustment before declaring it junk.
Old Oct 21, 2011 | 11:02 PM
87 vette 81 big girl's Avatar
It is 1 of 2 possible issues taking place in your 700 R4.
There is a problem with the 2nd gear servo in the 2-4 servo assembly that activates the 2-4 band.
Or there is a problem with the stock sun gear shell.
Sun gear shell may be cracked or half stripped out splines.
The 2-4 servo assembly can be serviced without removing the trans from your Corvette.
BR
To junk trans 700
