86 operating temperature.
Old May 4, 2002 | 11:20 PM
1986corvetteman's Avatar
1986corvetteman
8th Gear
Default 86 operating temperature.
is 200 to 220 degrees anything to worry about? if so then what is optimal operating temp.?
scorp508's Avatar
scorp508
That sounds about right for a stock 86 with an unmodified cooling system. :)
Old May 4, 2002 | 11:25 PM
vader86's Avatar
vader86
Default Re: 86 operating temperature. (1986corvetteman)
yes thats normal, so be sure to use Mobil 1 synthetic, as it can take the higher temps better
Old May 4, 2002 | 11:27 PM
1986corvetteman
8th Gear
Default Re: (scorp508)
we rodded the radiator, put in a new water pump, and were using a 190 degree thermostat. and running the AC adds about ten degrees to the temperature.
Old May 4, 2002 | 11:46 PM
vader86's Avatar
vader86
Default Re: (1986corvetteman)
you need to run a 160 tstat, with a custom chip, your temps wont leave the 180-200 range
Old May 4, 2002 | 11:50 PM
1986corvetteman
8th Gear
Default Re: (vader86)
where can i get the custom chip?
Old May 4, 2002 | 11:56 PM
vader86's Avatar
vader86
best bet, if you have major mods (cam, heads, intake) is http://www.fastchip.com
otherwise, post again in the ECM section, and someone will burn you one for a lot less than Hypertech will charge you for the same thing. Talk to member Marcho Polo.
Old May 5, 2002 | 11:00 PM
rmedina's Avatar
rmedina
You really don't need a custom chip to lower the temp.. All you gotta do is get yourself a 180 or 160 tstat and connect your main fan so it's on all the time.
I'm here in San Antonio and my car only goes into the 200-215 range when the ac is on. Otherwise it's in the 185-195 range.
hope this helps,
Raul
Old May 6, 2002 | 01:49 AM
Corvette0096's Avatar
Corvette0096
Talk to Marcho polo Cf Moderator. He will hook you up with a chip. plus his prices are good!
[Modified by corvette0096, 9:50 PM 5/5/2002]
To 86 operating temperature.
