need help
Old Oct 22, 2011 | 01:55 PM
rickgonzalez's Avatar
rickgonzalez
3rd Gear
Default need help
Hi my name is rick, i have a 1991 vette w/97.000 org. miles, I have changed out , the ecm,map sensor,egr valve,tps sensor,plugs,rotor cap,air pump,iac sensor,ect sensor,injectors, still runs like crap, runs great for a while , but at slow speeds, it seems to load up,check engine light will come on, have to put in park to clear out and go, need some advise thaks rick
Old Oct 22, 2011 | 04:03 PM
sailorsteve's Avatar
sailorsteve
The next thing you should do, before throwing any more parts at it, is to pull codes. If you need help to do it, use the "search" here on the forum. It is not at all difficult, and no tools needed. When you have codes, post them and someone with '91 info will likely interpret them for you.
Old Oct 22, 2011 | 04:31 PM
RedTRex's Avatar
RedTRex
Codes is a good wasy to start....
I bet your fuel pressure regulator (FPR) diaphram is torn.....dumping extra fuel into intake, causing a very rich condition, O2 sensors freak and put the CEL on
Old Oct 22, 2011 | 04:40 PM
rickgonzalez
3rd Gear
Default Need help
The codes are coming up 32 and 33 , what to you think
Old Oct 22, 2011 | 07:21 PM
Muffin's Avatar
Muffin
Code 32 indicates an EGR system failure
Code 33 indicates a MAP system failure, High signal, low vacuum.
I do not have a 91 FSM to provide trouble shooting steps. Maybe someone will be along that can.
Give your arm a rest, quit throwing parts at it until you pinpoint what parts are needed.
To need help
