Callaway TT MAP sensor location
Old Oct 22, 2011 | 03:15 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default Callaway TT MAP sensor location
Hey guys,
I'm just wanting to confirm that the MAP sensor location on a Callaway twin turbo car is on the underside of the manifold.
I've heard and read that it may be on the firewall but we're fairly certain its not there.
Old Oct 22, 2011 | 03:21 PM
tequilaboy's Avatar
tequilaboy
As far as I'm aware, the Callaway's are all MAF cars. However, I assume that there must be a MAP sensor somewhere that is used for the micro fueler/AIC controller. Maybe its integrated into the microfueler.
Old Oct 22, 2011 | 03:34 PM
Corvette-Chris
St. Jude Donor '08
Good point.
It's throwing a MAP code on my Snap-On scanner.
I can see a 2-wire pigtail inserting on the direct underside of the manifold, but can't actually see a sensor or anything. I was wanting confirmation before proceeding with any work.
Old Oct 22, 2011 | 03:53 PM
tequilaboy's Avatar
tequilaboy
What year car? I forgot about 90-91 which should be SD
Old Oct 22, 2011 | 03:59 PM
Corvette-Chris
St. Jude Donor '08
88 I believe.
Old Oct 22, 2011 | 04:50 PM
AKS Racing's Avatar
AKS Racing
Originally Posted by Corvette-Chris
Hey guys,
Contact "gotjuice" on the CF. He is my brother, Arnold, and he has five (5) I believe of the B2Ks, and should be able to assist in your questions.
Old Oct 22, 2011 | 05:22 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Its a MAF car, no map sensor to my knowledge. The Microfueler worked off a vacuum line...kicked on when positive manifold pressure was read.
The car you're referring to is an 88. It has the 100+ kit so its going to have a slightly different that stock configuration ala the EGR etc.
Old Oct 22, 2011 | 06:11 PM
Corvette-Chris
St. Jude Donor '08
Ok, so did Callaway delete the MAP sensor? I'm just wondering why it's throwing the code.
Old Oct 22, 2011 | 07:48 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Im not aware that MAF cars had MAP sensors, Im pretty sure they didn't (that's either L98 or B2k)... only the speed density (90-91) cars had MAP sensors(including the b2k's).
Try this.
http://www.corvettefever.com/techart...ems/index.html
Old Oct 24, 2011 | 03:12 PM
bill mcdonald's Avatar
bill mcdonald
If it is a 90 or 91 that MAP will be located here like all plain l-98's.
The only sensor I know that goes under the plenum on an L98 is the air temp sensor. which is a decent sized hole. Are you sure the code is not for a MAT sensor? Just checking.
The reason I say this is because the MAP should be a 3 wire sensor. A MAT sensor located under the plunum is a 2 wire.
Old Oct 24, 2011 | 03:28 PM
bill mcdonald
Doing a little digging.
Code 33 appears to be a MAP code on the 90/91's
on the 80whatever to 89, code 33 is a MAF sensor related
Old Oct 24, 2011 | 04:43 PM
Callaway Chris's Avatar
0Callaway Chris
Former Vendor
Originally Posted by bill mcdonald
If it is a 90 or 91 that MAF will be located here like all plain l-98's.
Old Oct 24, 2011 | 07:02 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
I think that's supposed to read MAP.
Old Oct 24, 2011 | 07:07 PM
0Callaway Chris
Former Vendor
Right Thanks
Old Oct 24, 2011 | 08:24 PM
bill mcdonald
To Callaway TT MAP sensor location
