1990 with an inf rest code 42
Old Oct 23, 2011 | 07:09 PM
mypantera's Avatar
mypantera
Default 1990 with an inf rest code 42
I have done a lot of searching on the inf rest light and seat belt light that won't go off. The only code I get when grounding "K" is 12 (normal) and 42. I removed and cleaned both sensors along with trying to rest it using the on off method many times with no luck. I can't seem to figure out where I need to check next with the inf rest code 42.
Any advice?
Old Oct 23, 2011 | 07:49 PM
MrVette90l98mt's Avatar
MrVette90l98mt
Yeah, I have the same problem on my '90 as well. I did the same thing cleaning both sensors and clearing codes, but still get the light on. I diagnosed my issue down to either the right sensor and or the Diagnostic Energy Reserve Module (Under or behind the radio I think). Last time I checked the DERM's where fairly pricy and could only find them used (chances are they are bad) on EBAY. Since I don't plan on crashing into anything head on (it only works 15* off center anyway) I decided to live with having the light on and upgrade the brakes (C5 13" front, Baer 13" rears and GS 275/315 Sumitomo tires) to avoid an accident in the first place...saved me more than a couple of times now.
If you find any additional info on repair/replacing DERMs or sensors without costing an arm and a leg, I'm all ears.
Old Oct 23, 2011 | 08:22 PM
gmboileau's Avatar
gmboileau
Code 42 is not associated with either of the frame sensors. Code 16 is for the left sensor and code 26 is for the right.
Are both the seat belt light and the INFL rest on?
Old Oct 23, 2011 | 08:45 PM
mypantera's Avatar
mypantera
Yes, both the Infl rest and the seat belt light is on.
Old Oct 23, 2011 | 09:19 PM
gmboileau's Avatar
gmboileau
Code 42 indicates on open in the Indicator lamp circuit which can be caused by a blown cluster fuse or faulty indicator bulb. Since the lights are on this eliminates this possibility.
A loose connection that intermittently goes open can also trigger Code 42 which stays in memory until all codes are cleared. Trying to find that loose connection will be a pain. It could be at the bulb socket, a wire that goes open or a bad connection at the DIC or the derm.
It could also be that the derm is at fault, however, since it's a pain to remove and hard to find a suitable replacement making sure the wiring and connections are good are worth the effort.
Try clearing the codes with the on off method using a timer to measures the 3 second interval as it is very time sensitive.
To 1990 with an inf rest code 42
