crank pulley
Old Oct 23, 2011 | 08:18 PM
overdrawn's Avatar
overdrawn
Default crank pulley
Does anyone know if this will work to remove the pulley on a 92...im about to loose my mind...
http://www.harborfreight.com/46-piec...set-37824.html
Old Oct 23, 2011 | 08:49 PM
rodj's Avatar
rodj
The pulley or the hub?
LT1 is 2 piece setup; the pulley simply unbolts from the hub on crank
Hub requires the puller
Old Oct 23, 2011 | 08:54 PM
Captain rags's Avatar
Captain rags
Cruising
From under the car use a long rod to tap the pully fwd after removing the bolts the actual hub you will need a puller and the one shown i dont think will work unless you remove the steering.
Old Oct 23, 2011 | 09:02 PM
TWISTERUP's Avatar
TWISTERUP
If you're speaking of the crank balancer--you don't need a puller--some PB blaster sprayed around the area where the balancer slides on the hub may do the trick-if not a piece of 2x4 against the balancer and a hammer(from the under side of the Vette) should do the trick. You may need a helper to rotate the crank while you tap on the 2x4.
If you're trying to remove the hub itself from the crankshaft the puller you're looking at would be too long (wouldn't fit) with the engine in the car.
overdrawn's Avatar
overdrawn
I need to get the balancer off....it's stuck real good, I know about the wood n hammer and pb blaster, that's how i spent my Sunday, just lookin for a cheap n easy way out, thanks
Old Oct 23, 2011 | 09:07 PM
TWISTERUP's Avatar
TWISTERUP
I have let them sit over night after a good dose of PB blaster and had better luck next morning. You will win --but some can be a real b*tch.
Old Oct 23, 2011 | 09:12 PM
overdrawn's Avatar
overdrawn
Thanks. I will give it another shot Of The PB blaster and try again tomorrow.
Old Oct 23, 2011 | 10:40 PM
rodj's Avatar
rodj
http://forums.corvetteforum.com/c4-p...ller-tool.html
Old Oct 23, 2011 | 10:52 PM
Double Aught's Avatar
Double Aught
Is the hub the part you need to mark before pulling it off the crank in order to maintain crank balance?
To crank pulley
