Fuse Links
Also a good idea to post a picture, another 87 owner may be able to help if you do that, good luck.
it required a 30 amp breaker to maintain current to the fan from the relay. About what the motor required for start up. New replacement links are available in most all sizes at fusable link stores everywhere.
The links can all be ID'd in the FSM for their size. There are about 5 or 6 on the jump post.
The majority will be 12, 14 and 16 gauge. Those wires on the post are the most important on the car...ECM power source, interior, eng mngt...why would someone chop all those and risk destroying the entire harness and electrical system?
I'd try to keep the links and replace with new that you solder in place with heat shrink to cover the joints. Tape is nowhere near good enough on hot wires....
That chopped (butchered) harness pigtail is/was the primary cooling fan relay. It was right under the master cyl on or near the wheel well. It had a wire to a fusable link to the battery, a wire to the harness and wires to the relay and then fan.
Somebody butchered the wires trying a bubba bypass when they applied their 1960 mechanical/technical knowlege to a computer controlled engine.
I guess they could'nt find a flex-fan to fit the water pump pulley....
If you want to salvage this car, get yourself an older FSM that has
the 2nd book for electrical in color. Its the exact same color codes in the book as the harness on the car, which makes it ten times easier to read and follow.
Good luck and I applaud the effort to save a great yr model.
I've owned several 87's all with various options and still have a DD in the driveway.
If you have any questions along the way, feel free to ask. There isn't much about an 87 that I have not seen or repaired or replaced...
1st tip: The cars grounds are more important to engine control than the hot wires are. Everything is monitored or managed thru ground path completion. Power is always ON. Its the grounds that get completed or disconnected to make something work. Also, anything that uses the ECM for mngt will have a "reference" voltage signal sent from the ECM thats used as reference. Thats typically 5v but can vary.
Enjoy.
half the fun in salvaging an old car is learning how to get to the Harbor Freight store in your city !
I cannot think of what else (OEM) that would be there...Fuel relay is near-by...around the corner by wheel well... MAF relays behind battery.
It had to be somebodys add-on junk for some device they took with them when they sold the car.
On the way home, he now found the car to be overheating (duh, no fans). Not to be disheartened, he quickly cut the main wire going the fan, butt spliced a piece of green #18 wire, strung it tightly from the left side of the radiator back to the fire wall, then spliced a #14 red wire to it, strung it tightly across the fire wall over to the heater, down the fender, through the door jam, and neatly stripped the wire, and stuck in the instrument fuse socket. Amazing........................!!!!!!!!! ! "Ya have a good day!"
