1986 Automatic Trans Whine???
Old Oct 25, 2011 | 10:41 PM
rrt898's Avatar
rrt898
Default 1986 Automatic Trans Whine???
I here a "whine" when the car is in park or neutral. The trans shifts fine. The "whine" may have been there for a while because now that it is getting colder the windows are up and its easily heard. I did have the trans rebuilt in August. Any ideas.......
thanks....
Old Oct 26, 2011 | 08:59 AM
Keystring's Avatar
Keystring
It might be your torque converter starting to go.
I've never heard an automatic tranny whine, but the converters certainly will.
Check your fluid levels.
The only way to really check is to put the car up on a lift and listen near the inspection cover.
Old Oct 26, 2011 | 10:08 AM
rrt898's Avatar
rrt898
I will check the car on a lift. I know that new parts can fail also but; the torque converter is new also. At least I have a warranty.
Old Oct 26, 2011 | 07:39 PM
cshuman's Avatar
cshuman
Is the detent cable adjusted properly? I missed around with that adjustment on mine before and as I remember it made it wine some. Once I had it set correctly the wining stopped.
Old Oct 27, 2011 | 03:56 AM
Cliff Harris's Avatar
Cliff Harris
Sometimes the pump will whine if the internals are worn.
Old Oct 27, 2011 | 07:24 AM
rrt898's Avatar
rrt898
The trans is rebuilt with a bigger pump........
Old Oct 28, 2011 | 01:57 AM
Cliff Harris
The pumps are all the same size. The difference is in the number of vanes. The early pumps had 7 vanes. In late '87 they went to 10 vanes and in the mid '90s they went to 13 vanes. Supposedly the higher vane count gives better pressure at high RPMs. They also claimed that the 13 vane pumps were quieter than the earlier ones.
Old Oct 28, 2011 | 07:26 AM
rrt898's Avatar
rrt898
That's what I ment. A later pump with more veins was installed. Never the less the pump is new, converter, kevlar bands, etc.
thanks....
To 1986 Automatic Trans Whine???
