what is a coilover?
Old May 5, 2002 | 02:40 PM
David Haag's Avatar
David Haag
Default what is a coilover?
please describe in detail
Old May 5, 2002 | 02:41 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: what is a coilover? (David Haag)
"Coilovers" are when the shocks are inside the suspension spring.
Old May 5, 2002 | 02:47 PM
David Haag's Avatar
David Haag
Default Re: what is a coilover? (Alchemist)
can that be done to a c4? what happens to the factory spring?
Old May 5, 2002 | 03:13 PM
Raysur's Avatar
Raysur
You remove the stock springs. It can easily be done. It costs $1,000+ however.
Old May 5, 2002 | 07:39 PM
Angelsword's Avatar
Angelsword
Alchemist,
I just completed the conversion using a kit from Doug Rippie Motorsports.It can be done in a home shop. The most dificult part is replacing the old bushings. When it's all done...WOW !
Old May 5, 2002 | 08:32 PM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default Re: what is a coilover? (Angelsword)
Alchemist,
Explain..."WOW" :)
What are your impressions?
Old May 6, 2002 | 04:28 PM
GRX's Avatar
GRX
Default Re: what is a coilover? (365ZUM)
ttt
Old May 8, 2002 | 10:43 PM
Angelsword's Avatar
Angelsword
Re: WOW !
The handling is much improved. The rear wheel hop, when you corner on an uneven road surface is gone. The steering is like a go cart.
Only problem may be that I opted for a spring rate that is going to be too heavy for a car that is driven mostly on the street. I'll let you know in a few weeks.
So far, I'm very pleased with the results. Before I can realy see how well it will corner, I have to replace my rear tyres...someone wore them out...
Old May 8, 2002 | 10:55 PM
365ZUM's Avatar
365ZUM
:cool: :cheers:
Old May 9, 2002 | 02:21 PM
jcazin's Avatar
jcazin
the only benefit of a coilover conversion on a Vette is the ease of tunability in regard to spring rate and ride height adjustments; the coilover conversion actually increases unsprung weight, and 84/87 Vettes require mods to the front shock towers- no real benefits for the street
To what is a coilover?
